Sky InsuranceBadger5
    Sep 2013
    33
    TTRS front brakes upgrade for 8P S3 queries..
    Appreciate any help on this topic,
    I'm doing a TTRS front brakes conversion on my 2009 S3, the TTRS calipers have already been acquired from ebay including carriers and other necessary bits. Now for the discs, I want to see if there are any good two piece lightweight OEM replacement options. What lightweight TTRS discs would you guys recommend and where is the best place to source them? Would prefer something significantly lighter than OEM but at a reasonable cost of course.
    Another question is on fitment under 18inch Enkei PF01s ET45, would these wheel clear the TTRS front brakes?
    Also with stainless braided lines, do I need to get S3 or the TTRS version for this application?
    TIA!
    Muzza80's Avatar
    Oct 2013
    Glasgow
    563
    I'm not aware of any aftermarket discs for the TTRS so most likely it will be Audi parts you need, they wont be light that's for sure!
    I'm pretty sure you can just re-use the S3 lines when fitting the TTRS calipers so S3 braided lines should be fine, the fittings are all the same anyway.
    2010 Audi S3 Sportback Black Edition TFSI Quattro
    Sep 2013
    33
    Quote Originally Posted by Muzza80 View Post
    I'm pretty sure there are a few options (aftermarket TTRS discs) out there but I have no experience with these products before hence the question.
    But thanks for clearing the question on brake lines. This American company I'm dealing with has only braided lines for Mk5/Mk6 Golf Rs, and since S3 is not sold in the US, they are not sure if these lines would fit my car.
    Morells's Avatar
    Aug 2012
    Hay-On-Wye
    366
    The standard ttrs discs warp mine went in twice to Audi for new discs and they never took my advice into account after 5k each. The problem is if you heavy brake and get them warm they warp common known problem. Go onto the TT forum for answers on what discs most of them run and it won't be oem. Hope that helps.
    New Car
    Audi S3 Sprint Blue Oscarli Stage 2+
    Old Cars
    Audi TTRS 2010 Phantom Black Oscarli Stage 1
    Audi S3 2009 Facelift Ibis White (Recaro Buckets)
    Audi S3 2009 Pre-Facelift Solar Orange Oscarli Stage 2
    Audi A1 185 2011 White
    XFi
    Jun 2010
    344
    There is a new revised disc ending in F rather than E. There is the Loba or AP floating discs though but these are 1k a pop or something!
    VAG_BADGER's Avatar
    Ricers in the rear view!
    Jan 2011
    Sheffield
    87
    AP Racing are about the best option for the 8P, as mentioned though you'd be spending well in to 4 figures for a pair.
    Whatever 18" wheels you have you will need a 5mm spacer minimum. I've got Team Dynamic Pro Race 1.2's on mine which are for touring cars and designed to wrap calipers, still just catch with no spacer ET45. Golf R braided lines are the same as the S3, you have to mod the small metal bridge pipe to fit in the caliper though, I bent it round a bar to give it the correct angle.
  1. Audi A4 B7 2.0T Full Brake setup front & Rear (Upgrade for B6)
    By docurley in forum For Sale/Wanted - Audi Parts
    Last Post: 1st May 2012, 22:13
  2. Potential front brake upgrade for A4 B5's
    By Foxmeister in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th March 2011, 20:49
  3. S3 8P Brake Upgrade for PD170
    By Indie_DSG in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th July 2010, 13:35
  4. Front brake upgrade?
    By unikarl in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th June 2010, 23:31
  5. front brake upgrade
    By batty in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th April 2008, 16:38
