Sky InsuranceAH Fabrications
Results 1 to 26 of 26
    Jan 2013
    57
    A3 170 tdi down on power
    Had my car on the RR today purely a power run to get some bench figures so I know where I'm starting at and also to see if there is any underlying issues.
    Turns out the car is making 161bhp and 226ft/lb
    I would expect to see at least 190
    Car has got egr delete/ dpf removed and remap from prior owner, but I haven't got any paperwork on this work other than the bill.
    Graph below shows the curves.
    Any gurus on here shed any insight as to where to start looking to try and iron the problems out.
    Torque, Torque, Torque
    Jan 2013
    57
    nothing?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    807
    Power Output 167 bhp Torque 258 lb-ft
    Audi A3 Hatchback (03-12) 2.0 TDI (170bhp) Black Edition 3d - MPG, Dimensions & Performance | Parkers
    If the maf isn't reading right it will effect it, you need to compare actual boost and requested boost no expert on this but check out the ross tech site for measuring blocks in vcds
    Growing old is mandatory, growing up is optional
    c_w
    1,050
    DPF-delete 170 can feel really quick for a 2.0TDI, I was very impressed with mine and felt that the clutch was on the edge all the time, if you breathed on the throttle at 35 in 4th it would take off.
    My currently 170 (standard) is much slower, but still reasonably quick.
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    683
    Definitely down on power. You need VCDS to see what is happening. Could definitely be the MAF. 215bhp and 340lb of torque is what I usually get out of them.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Jan 2013
    57
    Would the MAF not cause other issues aswell?
    Jan 2012
    Stockport, Cheshire
    683
    No, it's role is to limit the amount of fuel injected based on airflow. If it is dirty or tired it will read low and hence less fuel will be injected.
    Jan 2013
    57
    What about things like poor idle, poor mpg etc that I keep reading about.
    The car pulls well and doesn't feel like theres anything wrong but clearly there is.
    Jan 2012
    Stockport, Cheshire
    683
    It depends on what is actually happening to the MAF reading. Mog and idle won't be effected by a MAF that reads low across the board. You need someone with a scanner or VCDS to check what the MAF value is on full throttle. I can tell you then if that's your problem.
    Rick
    Jan 2013
    57
    Its going to my friendly VAG mechanic on monday and will be doing some investigative work.. Will update when know any more
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    688
    The other thing to bear in mind is that part of the EGR valve flow measurement is based upon the incoming air flow readings from the MAF. If the MAF doesn't read correctly the EGR can be flowing more hot gases back into the engine than it should under acceleration (the valve should close under hard throttle), thus losing boost & power.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    Mar 2014
    12
    Quote Originally Posted by c_w View Post
    Is DPF removal now an MOT failure? I know many garages wouldn't mind ignoring that but does it now technically make the car illegal?
    Sep 2011
    36
    The standard output is 167bhp AT THE FLYWHEEL.... you've got 161 AT THE WHEELS when it's gone through the gearbox / drive shafts / cv joints & rolling resistance of the tyres. Personally I wouldn't be overly disappointed tbh!
    Jan 2013
    57
    Quote Originally Posted by Bedders View Post
    Nope.. 161 @ fly 134 @wheels. Its says that clearly on the printout
    Sep 2011
    36
    Oops sorry couldn't see that as reading on my phone not pc monitor. Yep you've got a problem! Can you hear any top end high rev turbo whistles? Poss boost leak?
    What version of 170bhp motor have you got? Bmn by any chance? Plastic inlet manifold are known to crack / leak near the swirler valve motor! I'd get it boost leak checked before anything else.....if the full amount of boost isn't getting to the engine then you won't have the power. Another thing to consider is the age / mileage of the turbo. When they wear they have a habit of leaking oil from the bearing which them settles in the inter cooler pipe work. All buggers up the oomph getting to the motor. Good luck with sorting & let us know what you find out.
    Jan 2013
    57
    Yes its a BMN... Getting a smoke test done on monday and erg and inlet manifold coming off to see if they are gunked up.. Egr is blanked off and mapped out but since it was done before I owned it, I don't really know whats what, so as said above, things are coming to take a good look around..
    Sep 2011
    36
    Does engine look particularly smokey when under full throttle? If you've got a boost leak, sometimes not always, it may look more smokey than normal. Think it maybe down to over fueling as boosted air is escaping before it's thrust into the engine but it's still throwing in the juice so leads to more smoke than normal.
    Jan 2013
    57
    Not that Ive ever noticed..
    I'll update in monday if we gain any insight to the issues
    Jan 2013
    57
    Today the car had a smoke test, no boost leaks found.
    Scanned on vcds and no fault codes..
    Turbo has minimal play
    MAF Sensor was checked and the (actual) reading via vcds was 450-700 varying between idle and revved.
    Egr was taken off and cleaned, it had small amount of gunk but hardly anything and we discovered the erg has been blanked off as it should be. So at the moment no clearer picture what may be causing it.
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    807
    With the maf you do a 4th gear run and see what g/s don't you?
    Can't be massively different to a petrol :/
    Sep 2011
    36
    What mileage has it got on the car? Do you think the turbocharger might have been changed? Not sure how backwards compatible they are but think the 140bhp turbo looks similar on the manifold type. Think I'd be checking that first off....140bhp turbos are ten a penny & much cheaper whereas the 170bhp turbos are bigger compressor wheels & more boost. Worth checking the plate on the outer casing to make sure it's the right model charger! (Reason i say check is that is I've seen people changing the 170bhp plastic inlet manifold for the 140bhp as a replacement plastic one is £500 new when it breaks & they do, for an alloy one off a 140bhp £60 off eBay. Suppose someone could do same with a turbo charger) Just clutching at straws but watching this post with interest.
    max69vk's Avatar
    Apr 2012
    688
    140 turbo won't work on a 170 as the VNT is controlled differently between the 2.
    Bits for sale...
    Sep 2011
    36
    Quote Originally Posted by max69vk View Post
    Ah forgot about that yep isn't one vacuum n one electronic! My bad. Must be a reason for this motor being down on power.
    max69vk's Avatar
    Apr 2012
    688
    When was the fuel filter last changed? They're meant to be good for 50,000 miles according to Audi... I change mine yearly with the annual service as it's always full of crud.
    Bits for sale...
    Jan 2013
    57
    Fuel filter was done with last service, less than 5000 miles ago.. Today replaced the Egr valve with a dark side Egr delete pipe and now it has a intermittent hesitation under boost.. So now its probably got a leak or boost hose is collapsing perhaps thats what it feels like. Not related to the problems above though
    Jan 2013
    57
    So on further inspection today, Im almost certain the issue in the original post was EGR related, even though it was blanked and mapped out, perhaps it had an air leak (even though we checked) or maybe it was just being restrictive who knows...
    It now been replaced with a delete pipe... Big difference.. Pulls like a monster, however it now has a leak..
    Now Im almost certain it has a boost leak from the boost pipe that leads away from the anti shudder valve.. It must be twisting or moving slightly as when it holds full boost the car pulls like a monster and shows no issue from the original problem in original post.. Looking at the pipe the lugs look worn and seal had seen better days, so replaced the seal and has made a shade of difference but it still shudders and hesitates, so ordered a new pipe and will go from there..
    Would love to get the hard pipe kit from dark side but can't afford it at the moment
    Will fit over the easter weekend and will update then
  1. 2.5 TDi down on power
    By BX Bandit in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st August 2013, 07:44
  2. V6 tdi down on power and vibration
    By Yappy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th May 2012, 23:48
  3. TDi down on power
    By anilkumar in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2012, 11:59
  4. 2.5 v6 tdi down on power??
    By boya in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd August 2009, 13:07
  5. 170 TDI Power & Torque
    By killbill in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2006, 11:26
