JMB RetrofitsEM Tuning
Results 1 to 13 of 13
    Jan 2014
    89
    boost pipe popping off ffs
    ok driverside lower 90 bend is popping of intercooler side .
    do I go OEM replacement(yet to get a price) or get bayonet adapters (seen them £17 each) and silicone hose route?
    any other alternatives? s3 intercooler? have read self tapper it in but does this actually work and wont it damage the intercooler
    sabers's Avatar
    Oct 2013
    nottingham
    114
    try spraying hairspray inside the hose and on the intercooler then put together and leave to dry for 30 mins. worked for me.
    Jan 2014
    89
    With the metal bayonet ?
    sabers's Avatar
    Oct 2013
    nottingham
    114
    just jubilee clamps , this was on my jtd grande punto so I'm not sure on how the intercooler is fitted on a3s. picked the tip up of a scooby forum.
    Jan 2014
    89
    Totally different setup . On Vag cars
    May 2009
    south yorkshire
    628
    self tapper works straight through plastic and into cooler pipe ,wont really damage anything,one small hole ,alot cheaper than replacing the pipe work .
    Nov 2013
    Sheffield
    41
    Do not put a self tapper into your boost pipes it only creates another hole for your boost to leak out off hard pipe kit it from darkside or come or chop the end of ur boost pipe and inter cooler pipe n then jubilee clip it
    May 2009
    south yorkshire
    628
    Quote Originally Posted by Quattro colin View Post
    The tiny 3 mm hole will be filled with the thread of a screw .could even pop a small amount of pu adhesive over the screw head if you want it that tight . were not all sheep that follow people to buy from darkside and there inflated pricing. And i personally think chopping the end off tbe boost pipe and the intercooler and then trying to hold it sealed with a piece of tube and jubilee clips even worse than a self tapping screw . Without the lip on the ends of the pipes the jubilee clip and rubber or silicone hose will just pull off .
    Jan 2014
    89
    you are aware of how the hoses fit the intercooler right? cant see how on earth a jubilee clip will ever hold it on
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    942
    God I hate those pipes, such a poor design. They did it on purpose... I had the same problem with the passenger L shaped intercool. Replaced it, it was fairly tight but I said screw it lol, removed it, cleaned it dry of all oil and I put a generous amount of tiger seal around the metal bit on both ends and jammed it back in. Put the clip back, and then a massive big dollop of tiger seal around the two connecting pipes and intercool. Let it dry and it ain't goin nowhere lol.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Cheaper using body filler...
    Nov 2013
    Sheffield
    41
    I've put self tappers in my mk4 bolf running 2.0 bar of boost and all it did was make the leak worst in the long run
    Mr. B's Avatar
    Jan 2012
    Bristol
    942
    Quote Originally Posted by MrLapou View Post
    Sorry was that reply aimed at me? If so it's all I had, body filler is that not for body paint work type thing? How is it going to stop a pipe separating?
  1. Boost pipes popping off !!!
    By blucoop in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th July 2012, 21:06
  2. Anyone know size of boost pipe coming off k04 turbo ?
    By motfree in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2010, 14:05
  3. Pipe keeps popping off.
    By Dansmith in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st September 2010, 17:32
  4. Boost gauge going off the scale??
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th October 2007, 16:34
  5. Boost Pipe ?
    By A3-frankie in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2007, 18:03
