JMB RetrofitsSky Insurance
Results 1 to 28 of 28
Like Tree6Likes
  • 1 Post By SamA3
  • 1 Post By grchmason
  • 1 Post By S3_Jacko
  • 1 Post By Red s line
  • 1 Post By SamA3
Thread: HOW TO - Plastidip Guide To Spraying The Front Grill
    SamA3's Avatar
    Nov 2011
    71
    Okay so i spent today de chroming the front grill and getting it a nice matte black colour. Completely changes the front end IMO, but yeah here is the guide:
    Tools
    1 x Can of black Plastidip (£16 off eBay)
    2 x Small flat head screwdrivers
    1 x 100mm masking tape (didn't have any to hand to i used 24mm and 100mm clear low tack packing paint)
    1 x Microfibre Cloth
    1 x Glass Cleaner
    Step 1:
    Removing the 4 rings badge. Okay so i didn't get any photos of this actual process but what i did was prise the left side out with one screwdriver then insert the other to hold it out more then use the first driver to push the clip up and it should disengage. Its a very fiddly job but doesn't take long. I moved along doing all the bottom ones first then I did the two side ones. For the top 4 clips i didn't use the driver to prise simply pull down and out and then use a driver to push the clip and continue until all 4 are out and your rings are free! Leave the S3/S-Line badge on
    Step 2:
    Clean! to be fair it depends how dirty it is but my surround and center was pretty cleans so i just cleaned it all with a glass cleaner (fast drying/no smear) but you do have to make sure it is all clean and dry!
    Step 3:
    Tape Up! okay so i used 25mm tape for the close stuff then used a low tack 100mm tape for the surrounding areas. Here's the key part when you tape close to the edge DO NOT tape right up to the edge. This is because when Plastidip hardens it comes off as one and if you do it right to the edge your going to pull off the dip on the chrome as well. The gap also acts as a seam and the dip will actually tear in this seam. Don't worry plastidip comes straight off so its not going to affect your paintwork. For taping the S3 Badge just put a piece of tape over it youll find the backing plate is black anyway!
    Step 4:
    First coat! Okay so the first coat is going to be a really light coat at about 50% transparency. When spraying this stuff make sure your about 15 cm away, spraying on a horizontal axis with the can aimed slightly down (prevents overspray onto the radiator) and never stop on the areas your spraying always over spray and stop and go back on the tape. I made the mistake of stopping and i got a textured result on my first coat but hey ho its only the first one. Also i only did one pass over one area on this coat being as its more of a bonding coat. Now wait half an hour and go to step 5
    Step 5:
    Apply your second coat! Using the same method, horizontal action slightly tilted and only one pass over. Wait another 30 mins.
    Step 6:
    Apply your 3rd coat! Again same method. Wait another 30 mins.
    Step 7:
    Apply 4th coat! Now the coats should have really started to build so this time were going to do 2 passes over the whole thing. I would do one pass and cover it all then start again and do another pass. Again wait 30 mins
    Step 8:
    Apply your 5th coat! Same as 4th coat two passes over the entire grill. Now wait 45 mins - 1 hour.
    Result:
    Step 9:
    Remove Tape! Okay so start to remove the tape very slowly ensuring that the plastidip is coming up from in the seam/gap and off the paint work it should come off quite easily seems we have given it plenty of coats!
    here you can see where the tape ends and the plastidip starts, it almost acts like a tape itself!
    Step 10:
    Refit the 4 rings (very easy just push on, however make sure they are the right way up!) Clean off any excess but dont try to clean the plastidip just yet, and then stand back and admire your results!
    If you get any runs:
    This was my first go at it and i'm really impressed with the results. It wasn't perfect i did get a small run however if you wait the 30 mins till the run is touch dry then use your finger (with a glove on) dip in some thinners and rub the run until it is gone and then wait for it to dry and respray the entire thing again.
    This guide can be applied to any plastidipping, i used about 3/4 of a can for this i wanted there to be lots of coats for protection and it makes it easier to take off. I did it today in the shadow of my house but air temp was at about 13 degrees. I only waited 30 mins because i wanted to ensure it had ample time to dry. But it does take 4 hours to completely dry so try to avoid touching it for that amount of time. I wasn't worried about overspray onto the radiator because its distance from the grill ensures that the plastidip is well dispersed and it shouldn't cause any problems anyway as its still flexible up to 93 degrees!
    Anyway i hope this helps anyone that wants to spray their grill!
    Tonka Toy likes this.
    Dec 2013
    70
    A great guide & your grill looks great
    Ash88lfc's Avatar
    Jan 2014
    33
    Looks boss mate. Really considering but think I would ruin it no matter how instructed this guide is ha
    Jan 2014
    Berkshire
    335
    I personally would remove the grill if I was to go down this route as overspray gets everywhere!
    But FairPlay fella looks to be a great job!
    S3_Jacko likes this.
    SamA3's Avatar
    Nov 2011
    71
    Cheers for the comments guys. I thought about taking off the grill and i was abit worried about doing it but plastidip isn't like spray paint its very very easy to use and its quite targeted if that makes sense i.e when it comes out the can it doesn't disperse nearly as much as paint does. And the great thing is if it does go wrong you can just peel it off!
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Did you just do a thread on the instructions on the tin!? Also you have forgotten to glossify the surround....
    Good results for a temporary solution... Will look tired after 6months but fair play!
    grchmason likes this.
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
    Jan 2014
    Norfolk
    68
    There's always 1 that has to put a downer on things I personally think uv done a fantastic job the glossify from plasti dip is crap and pointless it does give it a slight gloss affect but personally I'd use lacquer All in all brilliant job mate
    southylad likes this.
    Audi a3 s line 140 bhp 2007 red. Jabba Sport remap 180 bhp, red carbon fibre wrap ,interior trim ,team heko wind deflectors, xenon bulbs white / ice blue , red audi badge , completely debadged on the rear , led mods in all footwells red , 18" s line rims , red alloy gaters , black plasti dip front grill ,
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Quote Originally Posted by Red s line View Post
    Yeah thats right... Use lacquer over plasti-dip!? I rest my case with that 1... Yeah fair job, but to do a how to thread is slightly over the top for plasti-dip when if you done a search on the forum theres 100's of threads on the same thing!
    I'm not quick to critisise...but to do a 'how to' thread without even taking the grill off the car, and doing the procedure correctly 100% slightly pushed my buttons a bit!! Lift that bonnet to a chrome top will look terrible in my opinion
    But fair play as I said to the attempt!
    SamA3's Avatar
    Nov 2011
    71
    Quote Originally Posted by S3_Jacko View Post
    Yeah thats right... Use lacquer over plasti-dip!? I rest my case with that 1... Yeah fair job, but to do a how to thread is slightly over the top for plasti-dip when if you done a search on the forum theres 1000's of threads on the same thing!
    I'm not quick to critisise...but to do a how to thread without even taking the grill off the car, slightly pushed my buttons a bit!!
    1000's?? find me one on an S3 grill..
    Also why take the grill off when you don't actually need to?
    You're right the instructions are on the can however some people that aren't as giftedly minded as you clearly are.. and need a bit more instruction plus some little tips on how to do it.
    As for the clear coat i didn't want a shiny finish i wanted a matte finish.
    Why bother criticising when it has clearly worked and i have taken my knowledge of this from a professional that does entire cars in plastidip with exactly the same method!
    Red s line likes this.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    I only bother critisicing 'as you put it' as its not the correct procedure to do your grill properly... If you titled a thread 'i've just plastidipped my grill' and gave advise rather than passing it off as a 'how to' thread then I wouldnt have bothered.. But to claim a 'how to' thread your method has to be 100% correct and if it isnt then prepare for some criticism off someone who knows how to do it properly!
    It as simple as that... Show me a pic of your edges after 2 months and you'll see exacltly what i'm talking about... And it doesnt specifically have to be a S3 grill.. A grill is a grill... Put platidipped grill in the search bar and see how many threads it returns!
    and I did give you kudos for the attempt!!
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    492
    Nice job m8, but poor radiator lol?
    Also clear laqure can be used over plasti dip to give a gloss finish^^ i have done a set of Focus RS alloys in blue then laqured them and they looked mint! Will upload pics tomorow, and before people say it wont come off? Of course it will because the base coat of Plasti Dip is already there,
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Quote Originally Posted by Jonathaan View Post
    I'm not saying lacquer cant be used... Of course it can.. But the whole point in plastidip is for a temporary colour change... And to laquer on plastidip, of course the base layer is plastidip.. But lacquer is lacquer and if done correctly will need to be chisled off rather than peeled....and will also make a right mess...
    Again I state that this was a fair attempt to be used by anyone as guidance... Shouldnt be passed off as a 'how to' thread tho.. Thats where my problem lies! And was only stating my opinion as what the forums are all about no!?
    SamA3's Avatar
    Nov 2011
    71
    Correct. However just because you "know how" doesnt give you the right to say this isnt a how to thread. Does it show how to do what i have achieved in the results pictured? You'll find the answer is yes and therefore it is a how to
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Have you plastidipped your full grill... No..! Youve just de-chromed it... And that hasnt even been done properly! So your title is wrong for a start!
    I'm not getting into a war of words with you cause i'll rip you to shreds... It was only my opinion and sorry that your ego cant handle that, but threads are open to positive and negative comments thats the beauty of forums...
    So I apologise for pissing on your bonfire on this thread but what I said is fact! If you dont like it then thats your problem... I was looking at your other thread aswell thinking you had some good ideas when others were criticising that also... So good luck to you...!
    SamA3's Avatar
    Nov 2011
    71
    How haven't I done the full grill?
    Clearly it's not me getting wound up by this apparently you need to be a rocket scientist to post a how to guide on this forum so I won't bother in future.
    Needless to say I think it's done the job I haven't stated this is the perfect guide and the best way I simply offered my advice to achieve the results I have got. Not surprising this forum lacks how to's nowadays
    y2kcurran's Avatar
    Aug 2013
    Fermanagh, N.Ireland
    118
    If someone wants to see a quick way to temporarily matt out their grill then this is a fine 'how to', the results look pretty decent man good job, although I also did wonder about the rad.
    “Whiskey, like a beautiful woman, demands appreciation. You gaze first, then it's time to drink.”
    Haruki Murakami, Hard-Boiled Wonderland and the End of the World
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    I'm looking at the slats in your picture and they still look grey to me... So hence my comment about the full grill... And trust me im not wound up by this either... I just stated that your how to thread was inaccurate... Yes it may be accurate to the way youve done it, its its by far the wrong way of doing it.... And you jumped down my throat with your defensive comment instead of taking critisism on the chin..
    1.. Plastidip is not as directional as you quoted.. Yes its different from paint with the way it settles but its still a spray and there is overspray...
    2. To achieve plastidipping the full grill as you know, you have to change direction of your spray to achieve the hard spots.. Therefore your radiator will be full of overspray plastidip... Not very good guidance for anyone wanting to do this..!?
    If you want to look up youtube and look at the makers of plastidips 'how to' there should always be some sort of cover behind your grill to stop overspray going onto your radiator...
    So your 'how to' guidance thread is wrong and therefore instructing people who do it 'your way' incorrectly... That was just my original issue, but since you couldnt take that on the chin.. I thought id explain in more depth
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    I only came on with a slightly negative comment rather than ripping this to pieces in the 1st instance... Didnt want to go down this road...
    Heres a 'how to'
    Look at no.1 on the list
    5 Areas of your Car You Should Mask Off Before Spraying Plasti Dip
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    So i think i'll leave that there... Been taken far too far anyway!
    SamA3's Avatar
    Nov 2011
    71
    How does that make sense? I'm explaining how to do it my way, so how can the how to of doing it my way be incorrect?
    Now that in your opinion might be wrong but you don't have to come over like billy big ******** and as you so aptly put it "piss on my bonfire"
    Regards to youtube: PlastiDip Car Emblems, Badges and Front Grille - Step by Step - DipYourCar.com - YouTube
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Plenty of experience of using plastidip.. So if my opinion is Billy big ******** to you then thanks for the compliment haha
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Kinda counter informative when you can clearly see the cardboard behind the grill on this 1 eh!?
    And an s4 grill is as close as you'll get to a s3 grill when they are practically the same...
    PlastiDip Car - Clear PlastiDip Over Chrome Makes Brushed Aluminum! - YouTube
    SamA3's Avatar
    Nov 2011
    71
    Okay so you avoided the question and then took me calling you billy big ******** as a compliment? Clearly you spend far to much time behind a computer or messing with your car to recognise basic human phrases. Don't worry though mister oracle I'm sure your right and I never said you weren't but that doesn't make me wrong
    SamA3's Avatar
    Nov 2011
    71
    Also I clearly stated in my OP that this was my first time plastidipping. Just a tip but maybe you should send me the how to in your 1st response instead of going off on one about how its not a how to because it's not perfect. I'm open to critisims otherwise why would I have out this was my first go?
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Quote Originally Posted by SamA3 View Post
    Yeah clearly I do eh!? I was obviously being sarcastic, so whos taking phrases the wrong way!
    I wasnt being critical about your 1st time doing it.. I even said you done a fair job! Did I not!? But on forums to claim a 'how to' means to me that its 100% correctly done as its a guide for all to follow to do it properly! Look at all my previous comments and see how many threads I actually cristicise on!? 0.... I just took exception as to how you went about posting this thread and couldnt bite my lip this time sorry!!!
    Again i'll state... That this was a fair attempt, but the way you are explaining it means that numerous people will be getting overspray on their radiators if they were to follow you... And again as you said it is a good guide and the majority of people wouldnt be able to tell the difference... I didnt wanna go down this road
    SamA3's Avatar
    Nov 2011
    71
    I really can't be arsed to carry on with this AFAIK a how to guide is a guide on how to achieve the results posted in said how to. That's it end of discussion if this isn't perfect enough for you then don't use it!
    P.s Ill add a little disclaimer for you so none can get confused into thinking this is suppose to be a perfect guide to. If that will make you happy this evening
  28. #27
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    N I think you need to tone down the sarcastic comments in future... Thats what set the the thing off if you read back! Grow up a little and take some critisism on the chin!
  29. #28
    Aug 2013
    Lancashire
    43
    Back on topic....
    Nice write up and nice job.
  1. Replies: 20
    Last Post: 30th November 2013, 16:55
  2. How to remove the S3 emblem badge front the front grill
    By willh92 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2013, 17:38
  3. how to remove the front grill on a mk2 TT?
    By stuarTTdi in forum TT/TT-S/TT-RS Forum
    Last Post: 8th September 2013, 18:44
  4. How do I remove Quattro badge from front grille?
    By monkeytrousers in forum General Technical / How To
    Last Post: 11th March 2010, 11:56
  5. How To Remove The Front Grill?
    By S3 Vermin in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2009, 13:12
