Monster MotorsportVolks Autos
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By scott909
Thread: Odd vibration in MY A3 8P
    Nov 2013
    24
    Angry Odd vibration in MY A3 8P
    Hi All,I have an odd vibration problem with my A3 2.0T 8P 2005 S-Line. It is very hard to describe but I would say it's worse at around 50-70mph and other than these speeds, very little vibration. The vibrations are felt throughout the car and the steering wheel.I've tried having all wheels aligned and calibrated to no avail.Getting very frustrated and any ideas or input is much appreciated.ThanksScott
    Nov 2012
    East Yorkshire
    207
    Have the wheels been checked and balanced?
    Audi A3 S-Line Sportback Black Edition
    White, 2009 2.0d 140bhp.
    DRL's, Xenons, RNSE, Bluetooth,
    to do
    Cruise, OEM Parking sensors, footwell lights, ambient light
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Tyre deformity?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    JulesW's Avatar
    Mar 2014
    Belgium , Hasselt
    Could be a dented wheel or balancing weights missing
    Mar 2014
    Skegness
    36
    I recently had this problem, at first with a bulge in a tyre, and then with missing ballancing weights on one side of the wheel.
    Sounds steriotypical to be more noticable between 50 and 70 as well so i would strongly suggest that, likely that google would confirm as well man.
    Take your care to a garage, Checking a wheel for ballancing is usually free of charge, if its not ballancing it wont cost you money, if it does need ballancing then itll only be a few quid
    Hope that helps bro
    JAMI308's Avatar
    Jamie H - Cumbria
    Sep 2013
    Cumbria
    29
    Follow JAMI308 On Twitter Add JAMI308 on Facebook Visit JAMI308's Instagram Channel
    I had the same when I first bought my car, quick trip to HiQ when I got home with the car... tracking / balancing done and the car felt like a new car! Cost about £20 all in!
    Nov 2013
    24
    The wheels have been balanced. I'll take the car in to the local tyre place and get them to check them over for tyre deformity. Thanks for all your help.
    Mar 2014
    Skegness
    36
    Good plan man, Let us know what happens please
    Dec 2013
    142
    I had this same problem when I fit 19" wheels from 18". Turned out to be hub rings needed to be fitted on all four wheels to finish a tighter and more secure fit. A mentioned though, could be
    many of the mentioned in previous posts. Hope you get it sorted cos it annoyed me just for 5 days. Wheel shop had to order them in.
    Nov 2013
    24
    Went to the local tyre shop today and they had a look. Turns out my rear N/S wheel is damaged and was therefore producing vibration through the car. They've temporarily swapped it out for an old used (working) one and voila, vibration is gone! They will make the repair of the wheel in the next couple of days and all should be well. Thanks everybody for your input!
    Hoesty likes this.
    Dec 2013
    142
    Glad you got it sorted
    Jun 2010
    East Manchester In the Hills !
    677
    I have just suffered 2 buckled wheels. Felt like a pneumatic drill was in the car with me. Doesn't take much to spoil the ride.
  1. Very odd vibrations
    By dentsy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 12th March 2014, 00:01
  2. Odd vibration top gear only
    By expat2000 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th October 2013, 16:17
  3. Odd vibration sensation through steering and floor
    By A4CAB in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th March 2010, 22:04
  4. Odd vibration when accelerating
    By Halgernon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2007, 00:11
  5. Odd Vibration Noise on startup???
    By NOGAROS3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th August 2004, 19:57
Tags for this Thread
