Chris NottBadger5
Results 1 to 9 of 9
    Nov 2013
    Some sort of fan is running
    Hi everyone
    When I turn my engine off and get out my car. There is some Sort of fan that still runs. It goes off if I start the car up again. Any idea What this could be
    Thanks!!,
    Jan 2012
    1,837
    Is it diesel by any chance? Does it happen all the time?
    Oct 2012
    29
    Yeh, if it doesn't happen all the time, most likely the dpf has been regenerating. This has happened twice for me so far. There was also a distinctive smell too iirc.
    |62 Plate - Audi A3 2.0 TDI 170 Black Edition| - |Glacier White| - |Comfort Pack| - |Interior Light Pack|
    |Light and Rain Sensor Pack| - |USB Console| - |Audi Exclusive Line Pack|
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,075
    radiator fan? Mine often runs for 30seconds or so after turning off the engine.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Mine used to do that, there are two fans one for aircon and one for rad. One of mine wasn't working so the other was working overtime. Have a look and check that they both work. Mine used to run after the engine switched off but since I got the other working it never happens anymore
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Nov 2013
    Hi All,
    Yes my car is a diesel, 2.0 170.
    i've only just noticed that the fan started to run after i turned off the engine..
    never stood and see if the fan stops after 30 secs,
    Think i pay more attention how long next time!!
    thanks
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Don't most of the water cooled turbo cars have an after run pump that circulates the coolant round the turbo when you turn off the engine to cool it?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Jameze's Avatar
    James
    Jul 2011
    Leeds
    525
    Quote Originally Posted by articuno88 View Post
    It's definitely this.
    OP you'll probably find your engine idles a bit higher than usual too and if you've got the gear suggestion on the DIS it will tell you to drive in a lower gear than usual.
    Oct 2012
    29
    Quote Originally Posted by Jameze View Post
    Affirmative.
    Whenever I notice the gear change on the DIS being funny I know the dpf is trying to regen. so I try to change my route where it can do so. Once the Start-Stop is working again, I know the process is complete.
  1. Cooling Fans Still Running ?
    By Studj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2012, 22:45
  2. Some sort of leak
    By b19rak in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th August 2007, 19:23
  3. Audi Cabriolet fans allways running!!!
    By Partyboy in forum Classic Audi Forum
    Last Post: 11th May 2007, 21:55
  4. just bought an s3 and im interested in purchasing some sort of vag cable.
    By nky_84 in forum VCDS (formerly VAG-COM) forum
    Last Post: 5th April 2007, 19:24
  5. This some sort of sick joke...???
    By silver75 in forum General Chat
    Last Post: 3rd December 2006, 10:32
