JMB RetrofitsVolks Autos
Results 1 to 11 of 11
    Sep 2009
    HORWICH,BOLTON
    35
    STEERING WHEEL REMOVAL
    Todays job is fitting cruise control, the only part im unsure of is the removal of the airbag. Not sure if it just pulls off from the steering wheel or if there are clips to release it. Any tips would be appreciated.
    The steering wheel is 3 spoke design (2005 sportback)
    27,121
    Unbolts from rear of wheel, 2 covers to remove 1st.
    Oct 2012
    Warrington, North West
    986
    as above, remove the airbag bolts, easier to turn the wheel 90 degrees on each side to get at the bolts. after bolts are removed, unplug the battery, then unplug airbag from the split ring, then job done, to remove the actual wheel you need a spline bit like a torx but with more fins on it if thats what there called.
    Sep 2009
    HORWICH,BOLTON
    35
    Removal of the steering cowling (top and bottom) reveals 2 bolts?
    Mar 2011
    Cleveland
    993
    No, the little caps are on the back of the wheel. Turn the wheel 90 degrees and you can see it at the top of the boss, facing the speedo. Prise it out , take out the screw, turn the wheel a half turn and take out the other one. It really is simple!
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Removing the control box at the base of steering column is tricky. Requires a pin/allen key of the right size to push in a hidden clip.
    Also be sure to NOT turn the clockspring. Tape it up before sliding off the spindle.
    I followed a great how to thread.
    Also coding required in two modules.
    Sep 2009
    HORWICH,BOLTON
    35
    Thanks for all the help, cruise control fitted. But now having issues with it working correctley .won`t resume and set button appears not to be working.
    Any ideas?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Did you code both modules using vcds?
    Sep 2009
    HORWICH,BOLTON
    35
    Yes,had to change one module to 0000042 and the other one to 11463 ,is this correct?
    Oct 2012
    986
    Couldn't tell you unless knew what your car has fitted and the options infront of me
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by ahtcap View Post
    Any ideas?
    If you have a steering module beginning with 1K0 then CC works in the 'alternative mode'. The SET button does nothing.
    To activate pull towards you and down, once activated press upwards to increase speed and downwards to reduce speed. CC will disengage when clutch pedal or brake is pressed. To resume pull towards you again. You can manually disengage by flicking the stalk away from you and de-activate altogether by pushing away as far as possible.
    You need a mid line steering module beginning with 8P0 for the SET button to work.
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
  1. Question: A3 Steering Wheel Removal?
    By reptor245 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2009, 21:32
  2. steering wheel removal
    By simonwjones in forum General Technical / How To
    Last Post: 7th July 2007, 16:11
  3. Steering wheel removal?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2006, 11:03
  4. Steering wheel removal
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th February 2005, 18:19
  5. A6 1998 > steering wheel removal with airbag
    By imported_terry2wheels in forum General Technical / How To
    Last Post: 1st September 2004, 21:32
