Badger5Volks Autos
    Yonner's Avatar
    Feb 2009
    Oldham
    150
    Car boosting strange
    Hi guys need some advice , car had been boosting weird , if input car into 4th gear and put foot down it starts to pull then when it gets to 3000rpm it will jump to 4000rpm and deliver boost weird , I have a video of this and will upload when I am on my pc later , after driving the car last night again it seemed like there is a boost leak now as it sounded like I had a dump valve and no boost in some gears ? Then other times it would boost ? Cheers for any input on this
    ninjakid's Avatar
    Mar 2013
    SW London/Surrey
    65
    Check your Diverter Valve, they are known to cause issues when knackered. Check which revision you have. Rev D seems to be the popular one, but I went to Rev G as I was informed it is the better of the 2.
    Mar 2014
    21
    Had this on my passat 1.8T turned out to be air flow meter faulty, replaced it and car pulled harder than ever
    Yonner's Avatar
    Feb 2009
    Oldham
    150
    Thanks for the suggestions guys , I put it on laptop and it had a MAF error , cleared it and all boost is back
    Yonner's Avatar
    Feb 2009
    Oldham
    150
    Guys boost don't seen to be there again and now the car started idling from 1k rpm and revving upto 2k and some times 3k on it's own while stationery ? I had it on vcds and this is the fault , any help appreciated
  1. Replies: 11
    Last Post: 27th May 2013, 09:36
  2. Replies: 2
    Last Post: 23rd February 2013, 22:11
  3. Car behaving strangely
    By Dazmo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th February 2012, 15:10
  4. Strange smell from underneath car
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2004, 16:01
  5. Strange sound coming front left of car
    By STOJ in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2004, 02:01
