Having browsed here for a while I've decided to register although unfortunately for help with my poorly s3
car is a 2008 S3, with around 42,000 on the clock, owned it for 6 months all was fine and dandy until this afternoon jumped in after work and the DIS told me my coolant was low, thinking nothing of it grabbed some G12 and popped it straight into the car, hopped in and off I went about 10 minutes later on pops the coolant light again, slightly concerning put it down to the car being up to temp filled again to the line and all was fine, left the car for an hour.
Went back out set off no problems drove for around 20 minutes as the car got up to temp the coolant light came on again, nursed the car for 2/3 minutes home, opened the bonnet and I have discovered I have a leak from the left side of the engine block coming out at a fair pace, browsed the internet for help stumbled across a few older TDI's with a similar problem one with a cylinder head problem one with a perished hose.
Hoping its the latter, anyone else had a similar problem and if so was it easily sorted?
