Badger5JMB Retrofits
Results 1 to 26 of 26
    Dec 2011
    62
    Audi A3 Facelift conversion now headlight side light not working
    Hello, finally converted my 2005 to 2011 spec frontend as had a minor collision in car park so the used parts were near enough same for both fronts,
    trying to get the sidelights in headlights to work but dont seem to, any one have any advice as everything else fits, do i require another switch or they require programming?
    all plugs seem the same and beam/ hazards/ indicators all work fine
    advice would b very much appreciated
    thanks
    Fopo's Avatar
    Feb 2014
    Sweden
    19
    Rather off-topic... But could you post some before and after pictures of your car?
    foxymk1's Avatar
    Apr 2012
    doncaster
    280
    i had the same problem but it is easy fixed, i took the light switch from the donor car as it had DRL on the switch
    as long as they dont have xenon or leds you have to move 1 wire in the plug , if you look at the plug it has 1 empty space where you move the wire to.
    i will have to look at mine to see witch wire it is as i had the other plug cut off the donor car to go off, i think its the pink/yellow that just wants moving
    Dec 2011
    62
    yeah will do as soon as its finished, u wouldnt tell its older model, taken a few months but at least got there, needed alot of the brackets/ clips which are all different
    Dec 2011
    62
    Quote Originally Posted by foxymk1 View Post
    very appreciated if you could let me know
    thankyou
    Dec 2011
    62
    hello again would i need the drl switch as well
    the lights are normal defo not xenons as they were way out of my budget with sets fetchin 650+
    thankyou
    Dec 2011
    62
    Quote Originally Posted by Fopo View Post
    wouldnt recommend u do the conversion unless u can find the bits used as the brackets which hold the wings will set u back £140 then the flitches have to be modified so the brackets fit, also the foam pads which sit inside the brackets again there £120+ new, without u will have massive gaps when open the bonnet or look down the edges which wil look stupid,
    also unless u do the work urself or have a mechanic/ bodywork mate u will b payin 0000's
    foxymk1's Avatar
    Apr 2012
    doncaster
    280
    Quote Originally Posted by cream2cream View Post
    thankyou
    im not sure i just took it as it was there and was from the same car
    foxymk1's Avatar
    Apr 2012
    doncaster
    280
    this is how my plug looks now
    so look at your plug and you will see that the top wire needs moving to make your plug look like this one
    Dec 2011
    62
    this is great, i'ii check mine in a bit, it looks like u cut the plug up to move the connector???
    thanks
    foxymk1's Avatar
    Apr 2012
    doncaster
    280
    no i used depinning tools but got abit angry with it
    you need to take the black plastic surround off then remove the purple slide clip then you can depin it
    foxymk1's Avatar
    Apr 2012
    doncaster
    280
    i think its the 4th 1 down in the same row of 5, so on the other plug take the pin from the top of the same row where the space is if you know what i mean
    pm me your number if you get stuck
    Dec 2011
    62
    hello, opened my plug and seems to b different the wires clips in different place??
    do u think it can b done or is this a task for the qualified proper garage mechanic?
    please look at the pic's
    thanks
    Dec 2011
    62
    hello anyone know how to upload pictures?
    Dec 2011
    62
    ive noticed that in my plugs there is no wire in no 10 but in no4 on facelift there is meant to b a wire, do u think this needs to b swopped over?
    foxymk1's Avatar
    Apr 2012
    doncaster
    280
    will swopping them make your plug look like mine? all i did was make my plug look like the facelift plug by swopping 1 wire and it worked
    foxymk1's Avatar
    Apr 2012
    doncaster
    280
    to upload pics you need a photobucket account
    Dec 2011
    62
    no mine has no wire in position 10 and int he facelift there is a wire in no4 but not in no10
    got a electrician comin tomorrow and will see if he can bypass, to get the annoyin bulb light off the dash and side lights to work, rear work fine was just plug and play with the facelift lights, fronts r another problem
    picture upload 2morrow
    Dec 2011
    62
    Hello, check the picture of my plug
    see pic below,
    its totally different compared to yours
    what ive noticed from a mate who's got a 2011 genuine facelift the blank is in position 10on his car and no4 on my car
    do u think its a straight swop over?
    thanks
    Dec 2011
    62
    the link dont seem to work, so ive uploaded a few links from photobucket
    http://i73.photobucket.com/albums/i2...psf6041742.jpg
    foxymk1's Avatar
    Apr 2012
    doncaster
    280
    that is exactly the same as mine mate, my pic shows what it look like after the swap
    foxymk1's Avatar
    Apr 2012
    doncaster
    280
    take the pin from the top left and fit in the empty hole
    Dec 2011
    62
    great
    http://i73.photobucket.com/albums/i2...psea29ff5e.jpg
    will get it now, also managed to chop a plug off a standard si will try and cut the pin and insert directly into mine then rewire
    will update soon as
    thanks for your advice
    foxymk1's Avatar
    Apr 2012
    doncaster
    280
    just swap the pin mate its simple no need to cut and rewire
    Dec 2011
    62
    works spot on, took a matter of minutes, mostly choppin the pin out of the donor plug
    http://i73.photobucket.com/albums/i2...ps0943b58d.jpg
    plug pushed straight in
    http://i73.photobucket.com/albums/i2...psad30bf8f.jpg
    will finish off wiring shink wrap join
    Dec 2011
    62
    its easier said than done mate tryin to get that pin out in one piece so got a donor plug frm local scrap yard and butchered the pin out of that, thanks alot of your advice much appreciated
  1. Halogen Headlight, side light and fogs upgrades...What bulbs
    By Tiffy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd November 2013, 18:48
  2. Help needed no headlights, side lights problem
    By Steven Butler in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th June 2012, 22:49
  3. 2006 AUDI A3 FACELIFT CONVERSION ADVICE NEEDED
    By Cloth ears in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2012, 13:34
  4. Replies: 7
    Last Post: 31st May 2011, 19:55
  5. Headlight - instrument lights not working
    By RS-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2007, 17:23
