Chris NottAH Fabrications
    Oct 2012
    Lincoln
    152
    Drivers door lock motor noise??
    In the last couple of days when I unlock my car, the drivers door locking motor makes an awful grinding noise.
    it doesn't do it when you lock it, just during the unlock.
    Anyone else had this problem? Is it a serviceable part or do I need to replace it?
    thanks
    27,114
    TBH mate if its what I think then better to replace the lock, could try removing & checking movements, but all the ones I've worked with just get replaced & the noise goes away then.
    Oct 2012
    Lincoln
    152
    Yeah, that's what I thought might be the case.
    Do you know what parts I need to order, I am quite handy with things like this, so I would prefer to gets the parts and do it myself, rather than get ripped off by the stealers.
    Thanks Nigel
    27,114
    Have you got vcds?
    Just the door lock mate, what's your vin, when I get 5 I can maybe check lock part no.
    Oct 2012
    Lincoln
    152
    Have you got vcds?
    Thanks mate.
    I will upload the VIN on here tomorrow, not got it handy at the moment, would appreciate that, if you get 5 mins. Not got VCDS either, thinking it could be a wise investment.
    Oct 2012
    Lincoln
    152
    Hi Nigel.
    My VIN: 8P89B012608
    Thanks in advance. :-)
  1. How to get to drivers door lock mechanism
    By just017 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st December 2011, 00:53
  2. Burning drivers door lock !!
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2009, 18:49
  3. Drivers door Lock - Central locking
    By andysAko4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th February 2009, 16:51
  4. Drivers door lock not registered as locked
    By WildBruce in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2008, 11:21
  5. a4 drivers door lock
    By MIDCO in forum Diesel forum
    Last Post: 5th December 2006, 12:50
