Volks AutosJMB Retrofits
Thread: coolant leak
    Jan 2014
    61
    coolant leak
    I have had my s3 in the garage having some work done ( water pump and timing belt) on the report it says there was coolant leaking from around the head gasket and may require further attention. He has cleaned it all up and rad sealed it. He took it out for a 10 mile drive got back and its bone dry now, But will this mean the cylinder head is on its way out ? Or should I not panic ?
    Jan 2014
    61
    Anyone ??
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Keep an eye on your coolant level. Don't panic. If it starts drop it take it to a garage and get looked at.
    VCDS USER
    Jan 2014
    61
    Ok mate cheers for the reply
  1. Coolant leak
    By petewon in forum General Technical / How To
    Last Post: 5th October 2006, 21:33
  2. A4 coolant leak
    By spud in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2006, 19:29
  3. Problems with S3, suspect coolant leak & Turbo dump/recirc Valve noise??
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 17:17
  4. coolant leak - need to id name of pipe
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th March 2006, 01:03
  5. Possible coolant leak, any ideas?
    By jgrand in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2005, 11:46
