Sky InsuranceChris Nott
    May 2008
    222
    8P 2005 2.0 TDI - Bluetooth Voice Rec, Parking Sensors + Other Faults VCDS Log inside
    Hi guys, after a few years away, done a bit of trading, here and there, got my self back into a really well specced Audi a3, came at a good price, but with a fair amount of faults, nothing major, but would like to get them sorted.
    Parking sensors do not work - all you hear is a constant beep.
    Bluetooth/Voice Rec, nothing at all, when searching nothing comes up, and when going into module 77, it will not connect, its like its dead, I have had the seat out today, and the module did not look damp etc?
    Included is a log with all faults, some may be linked?
    Any advise would be great, im pretty sure NHN will have some knowledge on this..
    VCDS Version: Release 12.12.0
    Data version: 20130910
    Tuesday,25,February,2014,15:06:36:24920
    Chassis Type: XX (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 76 77
    7D
    VIN: XXXXXXXXXXXXXXXXX Mileage: 134870km/83804miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    55-Xenon Range -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    76-Park Assist -- Status: Malfunction 0010
    77-Telephone -- Status: Cannot be reached 1100
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 DT HW: 028 101 189 2
    Component: R4 2,0L EDC G000AG 7000
    Revision: 12345678 Serial number: XXXXXXXXXXXXXX
    Coding: 0000078
    Shop #: WSC 06314 000 00000
    VCID: 78FB855A0BB213DEAC3-802D
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 042 F HW: 02E 927 770 AE
    Component: GSG DSG 070 0920
    Revision: 04507000 Serial number: 00000507060158
    Coding: 0000020
    VCID: 1627ABE221E6C5AE5EF-8043
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
    Component: ESP FRONT MK60 0102
    Revision: 00T12001
    Coding: 0021122
    VCID: 408B2DBA13E29B1ED43-8015
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 L HW: 8P0 820 043 L
    Component: KlimavollautomatH16 0200
    Revision: 019011 Serial number: 8P0820043L
    VCID: 35654C6E5C202EB6775-8060
    3 Faults Found:
    01301 - Control Module for Voice Recognition (J507)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 135
    Mileage: 54536 km
    Time Indication: 0
    Date: 2009.05.14
    Time: 00:00:06
    Freeze Frame:
    ON
    01855 - Temperature Sensor for Heated Seat; Left Front (G344)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 7
    Mileage: 134879 km
    Time Indication: 0
    Date: 2014.02.25
    Time: 14:37:41
    Freeze Frame:
    Temperature: 18.0°C
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 20
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 06:33:34
    Freeze Frame:
    Voltage: 9.00 V
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H36 1201
    Revision: 00H36000 Serial number: 00000002075032
    Coding: E58A5F06A214100000000000000000000008FE175C0200
    Shop #: WSC 06314 000 08192
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH10 0050
    Coding: 00150573
    Shop #: WSC 06314
    4 Faults Found:
    01505 - Bulb for Blinkers; Rear Right (M8)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 39
    Mileage: 134523 km
    Time Indication: 0
    Date: 2014.02.22
    Time: 14:47:00
    Freeze Frame:
    ON
    Voltage: 11.75 V
    ON
    ON
    OFF
    OFF
    OFF
    00988 - Lamp for Brake Light; Right (M10)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 33
    Mileage: 134523 km
    Time Indication: 0
    Date: 2014.02.22
    Time: 14:47:00
    Freeze Frame:
    ON
    Voltage: 11.70 V
    ON
    ON
    OFF
    OFF
    OFF
    00985 - Right Tail Light (M2)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 33
    Mileage: 134523 km
    Time Indication: 0
    Date: 2014.02.22
    Time: 14:47:00
    Freeze Frame:
    ON
    Voltage: 11.70 V
    ON
    ON
    OFF
    OFF
    OFF
    01506 - Bulb for Rear Fog; Right (L47)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 33
    Mileage: 134523 km
    Time Indication: 0
    Date: 2014.02.22
    Time: 14:47:00
    Freeze Frame:
    ON
    Voltage: 11.70 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H11 3520
    Revision: 91H1135 Serial number: 0037W000E82N
    Coding: 0071612
    VCID: 479936A636CCAC26159-8012
    Subsystem 1 - Serial number: 63328RB4007B7C6CX
    Subsystem 2 - Serial number: 63428RB400832CC2I
    Subsystem 3 - Serial number: 63528RB4007B7C97X
    Subsystem 4 - Serial number: 63628RB400832C87L
    Subsystem 5 - Serial number: 63729RB4008F890CZ
    Subsystem 6 - Serial number: 63829RB4008F8939-
    1 Fault Found:
    01218 - Side Airbag Igniter; Passenger Side (N200)
    001 - Upper Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 134879 km
    Time Indication: 0
    Date: 2014.02.25
    Time: 14:37:46
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 E HW: 8P0 953 549 E
    Component: Lenksäulenmodul H34 0070
    Coding: 0011142
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: Lenkradmodul H03 0080
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
    Component: KOMBIINSTR. VDO H80 0410
    Revision: D03 Serial number: 2246ED03001862
    Coding: 0000413
    Shop #: WSC 00751 751 80580
    VCID: 37794666462CDCA6659-8062
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 F HW: 1K0 907 951
    Component: Gateway H10 0120
    Revision: H10 Serial number: 280010570682D6
    Coding: 7F0F0FCA070101
    VCID: 2A5F6F12859E714EEA7-807F
    1 Fault Found:
    01303 - Telephone Transceiver (R36)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 7
    Mileage: 131026 km
    Time Indication: 0
    Date: 2013.11.27
    Time: 16:13:51
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D03 Serial number: AUX7Z0E6FNI0RJ
    Shop #: WSC 00000 000 00000
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 A HW: 8P0 035 192 A
    Component: RNS-E HIGH EU H70 0650
    Revision: 01S Serial number: AUZBZ7E0902655
    Coding: 0205713
    Shop #: WSC 06435 000 00000
    VCID: 2D55640EB47066760F5-8078
    2 Faults Found:
    16352 - Control Module - Electrical Error
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 89
    Mileage: 57305 km
    Time Indication: 0
    Date: 2009.06.08
    Time: 14:32:59
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 7
    Mileage: 134879 km
    Time Indication: 0
    Date: 2014.02.25
    Time: 14:58:02
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
    Part No: 8P0 959 801 F
    Component: Tuersteuerger. H10 0040
    Coding: 0000120
    VCID: 3E7753426916EDEEA6F-806B
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.079 H07 1806
    Shop #: WSC 00052 210 66363
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H03 0040
    Coding: 108000186D288405488AC67300
    Shop #: WSC 00751 210 61346
    VCID: F9FD005EB0B88AD653D-80AC
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH25 0160
    Revision: 00003 Serial number: 10000001266369
    VCID: F0EB3D7AE3C2CB9EE43-80A5
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
    Part No: 8P0 959 802 F
    Coding: 0000120
    VCID: 3F892E466E1CE4E6AD9-806A
    1 Fault Found:
    00944 - Heated Exterior Mirror; Passenger Side (Z5)
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 C
    Component: Dynamische LWR H01 0010
    Revision: 00000000 Serial number:
    Coding: 0000001
    VCID: 3A7F5F52753EC1CE9A7-806F
    5 Faults Found:
    01314 - Engine Control Module
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 40
    Mileage: 122584 km
    Time Indication: 0
    Date: 2013.06.02
    Time: 23:48:23
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 40
    Mileage: 122584 km
    Time Indication: 0
    Date: 2013.06.02
    Time: 23:48:23
    01317 - Control Module in Instrument Cluster (J285)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 40
    Mileage: 122584 km
    Time Indication: 0
    Date: 2013.06.05
    Time: 20:16:57
    01299 - Diagnostic Interface for Data Bus (J533)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 40
    Mileage: 122584 km
    Time Indication: 0
    Date: 2013.06.05
    Time: 20:16:57
    00070 - Starting Battery Voltage
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 15
    Reset counter: 248
    Mileage: 131032 km
    Time Indication: 0
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205713
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 89
    Mileage: 57305 km
    Time Indication: 0
    Date: 2009.06.08
    Time: 14:32:59
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 7
    Mileage: 134879 km
    Time Indication: 0
    Date: 2014.02.25
    Time: 14:58:02
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 A HW: 8P0 919 283 A
    Component: Parkhilfe 4-Kan H09 0010
    Revision: 00H09000 Serial number: 00067824820518
    Coding: 0001103
    Shop #: WSC 131071 1023 2097151
    VCID: 397D405E7038CAD693D-806C
    3 Faults Found:
    01548 - Sensor for Parking Aid; Rear Right (G206)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 23
    Reset counter: 162
    Mileage: 122587 km
    Time Indication: 0
    Date: 2013.06.03
    Time: 00:34:13
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 172
    Mileage: 130183 km
    Time Indication: 0
    Date: 2013.09.17
    Time: 15:16:43
    01543 - Parking Aid Warning Chime (H15)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 46
    Mileage: 132274 km
    Time Indication: 0
    Date: 2014.01.09
    Time: 14:56:30
    Address 77: Telephone
    Cannot be reached
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    May 2008
    222
    Bump
  1. Retrofits - Bluetooth/Cruise Control/Parking Sensors
    By wrightyrx7 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2014, 15:55
  2. Bluetooth Voice Control
    By Lion Man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2009, 16:01
  3. Disillusioned driver of a 2005 2.0 TDI A3 5dr
    By COLDSTEEL in forum Diesel forum
    Last Post: 13th June 2009, 11:31
  4. Ideal Oil For 2005 2.0 TDI
    By Evo_Mic in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th February 2009, 17:39
  5. 2005 2.0 TDi S-line Faults
    By razputin in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th February 2008, 20:41
