JMB RetrofitsEM Tuning
Page 1 of 2 12 LastLast
Results 1 to 40 of 73
Like Tree8Likes
Thread: Engine problems.
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Engine problems.
    Hi guys.
    Pretty sure my turbo just gone.. Cruising along at about 50 and then slowed down for a roundabout tryed to pick up the speed and nothing. No boost or anything. When the car gets to about 3k revs it just judders a little and doesn't pick up speed. Anything i can check before it goes to the garage on monday morning?
    The car is a Audi s3 2007 with just 42k miles.
    thanks guys!
    Jan 2014
    Oxford
    27
    Hi. When you say it judders at 3k RPM, will it rev over 3k ? or just stay there and judder. If so, then It sounds like the ECU is in Limp Mode. I would get it on a tester to see if there are any codes stored to indicate what part mate it go in Limp Mode.
    Any simple OBD scanner can read generic codes, even if you use the likes of Torque app and an bluetooth OBD plug. These might not give the same amount of detail about found codes, but it still displays them if they are there. The app is around £2 and the plug about £7-£10.
    HTH
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Quote Originally Posted by omblad0n View Post
    HTH
    Hi thanks got the reply. The car goes over 3k rev's. But it's just very flat! There has been no engine light or anything came up on te dash.
    Jan 2014
    Oxford
    27
    It does sound like the turbo then, but cant really say. I would still try to read the codes, in my experience, if the EML is not on, it doesn't mean there are no faults. Might be something like an actuator, or boost solenoid, etc. 42k is low mileage for a turbo to go. You'd notice white or blue smoke from the tailpipe when the turbo starts to go.
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Just took the car around the block, The car will judder when it gets to about 3k but it will go over 3k. The engine emission light's just came on too.. The car's going in on monday. :/
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    670
    Have you checked all hoses are securely connected that relate to the turbo.
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Quote Originally Posted by Dan-Jnr View Post
    Yes iv checked everything like that! Everything seem's intact.
    Dec 2013
    142
    A mate thought his turbo turned cactus on his golf R, same sort of prob. Changed intercooler and that solved the problem. Hope it's not the turbo as it shouldn't be as that much on the clock.
    Audi-Rog's Avatar
    "Fire up the Quattro!"
    Dec 2009
    Milton Keynes, United Kingdom
    168
    Add Audi-Rog on Facebook
    Check the Diverter Valve, sounds like it may have split, easy fix if it has.
    |Audi S4 B6 4.2 V8..gone|A3 TFSI Q S line..gone|
    |Current: Audi A3 3.2 V6 DSG
    S line|BBS Carlitos|
    |K&N Panel Filter|Superchipped 265 BHP|
    |Link
    :FREEMAN:detailing Milton Keynes|
    Jan 2014
    Oxford
    27
    Get it on a scanner before it goes in to know what to expect. might be an easy fix to do on a Saturday afternoon. There must be a member close to you with vag-com or some sort of scanner that would be willing to come around and scan for a couple of pints!
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    670
    When my S3 8L did the same as what you're suggesting the Turbo Intake Pipe popped off the turbo.
    Just glancing at it didn't show the problem, the clip to tighten it was loose causing the TIP to not be fastened securely.
    I would double check all pipe work from intake, intercooler, turbo and exhaust by trying to pull it off to confirm its tight.
    [8L BLOG] [8P BLOG]
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Thanks for the suggestion guys! I'll have to have a closer look tomorrow! When i think back there was a funny nose at about 2300k rev's. Cant even explain the nose! It was weird. Didn't think anything of it though, Thought it might of been the wind.
    Jan 2014
    47
    Sounds like a huge boost leak, a hose might have blown off, failed diverter valve, or wastegate stuck open.
    2.0 TFSI / Go Fast Bits Atomic / Go Fast Bits DV+ / Precat Delete / MAP Diode Mod / 250hp@19psi / Stock Software
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Just wondering aswell guys. Where abouts is the diverter valve?
    Thanks for the suggestions also! Ill keep you all updated after iv had a look tomorrow!
    Jan 2014
    47
    Oops! turns out it is mounted differently on the S3
    Its mounted on the turbo, access it from underneath. It has three 5mm hex bolts, the top one is a major pain in the arse.
    XFi
    Jun 2010
    337
    Quote Originally Posted by Flexiblemouse View Post
    Not on an S3 it isn't, 4 torx bolts and it's off. Located just behind the radiator and left of the intake pipe.
    Oggy-s3 likes this.
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Thanks alot guys. Ill report back tomorrow!
    S3Alex likes this.
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Just been to have a closer look and I removed the engine cover etc and I couldn't see anything. So loose pipes and the diverter valves looks all intact.
    Now I removed the maf sensor and there was no change in idle. No drop in revs etc.
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    I would have immediately thought about loose pipes / boost leak as well. Would be very shocked at a turbo going with all the miles you have done! Keep us updated mate. But Im thinking it will be a simple fix for you
    Audi S3 8P3 / REVO Stage 1 / REVO Ceramic Intake / NGK Iridium Spark Plugs / LOBA HPFP / Philips Diamond Vision 5000k Fog Light Bulbs /
    KW V3 Coilovers / Team HEKO Wind Deflectors / Bridgestone Potenza S001 92Y Tyres / Complete LED Bulb Conversion (int' + ext') / Ashtray Delete /
    TTS Engine Cover / Alpine 928r Multimedia Station (8in screen) with integrated Bluetooth, Sat Nav etc / Ross-Tech VCDS Owner.
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Cheers trev! I'm not as worried as i first was when it happened! The car's booked in to Falcon Performance over at skippers lane, Middlesbrough on monday, I'm pretty pally with them so i think if it's something simple they wont screw me on it!
    s3_trev likes this.
    Jan 2014
    47
    Did you take the diverter valve off to see if the diaphragm is split? You should check the wastegate actuator too
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    I wouldnt know what i was looking for tbh flex!
    crazylegscrane's Avatar
    May 2008
    London
    156
    I had a similar problem where I couldn't drive above 3k revs in any gear as a bad misfire had the car juddering. Had one of the injectors replaced and that cured the problem.
    The fault code shown was a misfire on cylinder 3 but swapping coil packs and plugs round didn't move the problem to another cylinder. I had new plugs and coil packs but it was the injector change that cured it.
    S3 Sept 08 to.....
    A3 2.0 TDI Sport April 04 - May 08
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Quote Originally Posted by crazylegscrane View Post
    Had a similar problem not long ago! I had misfire in Cylinder 4 and it was the injector. But i didnt feel as bad as this.
    May 2008
    London
    156
    Well, I've had two injectors go as well, the first was very noticeable as described above the second I was driving the car for 2 months just thinking it was rough with cold starts but the wife kept telling me my car sounded different so it went to AMD, they tried the plugs/coils again but no cure so changed the injector and the problem went away.
    Same problem but one was way worse than the other
    S3 Sept 08 to.....
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Well the car has been dropped off at the garage my mate sent this. Said hopefully have a update later!
    Hoesty likes this.
  28. #27
    Aug 2013
    Surrey
    134
    Quote Originally Posted by Oggy-s3 View Post
    I have a misfire on idle, suspected injector, do you remember how much an injector is roughly?
  29. #28
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Quote Originally Posted by Granta View Post
    I havnt a clue mate. The garage sorted it. Maybe ebay will have them?
  30. #29
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,301
    Approximately £120-140 each depending on where you can get the best price.
    Audi S3 2.0TFSI Injector (Each) - JBS
  31. #30
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Visit s3joe's Instagram Channel
    Does not look good that
  32. #31
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    Any update mate?
  33. #32
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Noo still not update. Which to me is bad sounds like its gonna be bad news.
  34. #33
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    632
    Have they checked the diverter valve yet?
    An 07 will have the old C type on which do fail pretty often.
    Only a 10 minute job to replace and a new G valve is about £40 or a D is about £60
    IBIS WHITE S3
    Revo stage 2+ and loving it
  35. #34
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Quote Originally Posted by Marshy View Post
    No mate i didnt have chance! Just put it straight in the garage!
  36. #35
    Nov 2013
    cardiff
    39
    ye mine fell apart when i took it out lol
  37. #36
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    632
    Yeah but have the garage checked it?
    May save you a fortune on labour that's all.
    IBIS WHITE S3
  38. #37
    Oggy-s3's Avatar
    Dec 2013
    Middlesbrough
    128
    Aye that's true mate. I know the garage pretty well. Family and i use them very often. Hopefully wont be too steep! Thanks for the heads up.
  39. #38
    Jan 2014
    Berkshire
    305
    Oggy sorry to hear this fella but as above i'm sure it will be something simple it normally always is fella!
    Keep us updated!!!!!!!
    Oggy-s3 likes this.
  40. #39
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    554
    Also could be the throttle body
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
  41. #40
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    632
    Yeah good call that'd be the next port of call if the dv was ok.
    IBIS WHITE S3
  1. 2000/2001 A3 TDI (ENGINE PROBLEM)!!!
    By mr964porsche in forum Diesel forum
    Last Post: 26th June 2006, 23:32
  2. Diesel Engine problems
    By sinbadfury in forum Diesel forum
    Last Post: 16th May 2006, 15:26
  3. 2000 A6 2.8 Quattro engine problem
    By bullcell in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th August 2005, 23:02
  4. hot engine problem , can anyone help please ????
    By Jonny_doe in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th January 2005, 20:33
  5. Engine Problem - 2.6 V6 - possibly ECU Fault -
    By imported_k15hvc in forum Classic Audi Forum
    Last Post: 11th July 2004, 21:40
