Badger5Sky Insurance
Page 1 of 2 12 LastLast
Results 1 to 40 of 41
Like Tree21Likes
Thread: ST or H&R springs for S3?
    Dec 2013
    142
    Hey guys
    Anyone using ST springs or H&R springs to dump their S3?
    Considering 25mm all around by H&R...or....ST 30mm front and 20mm rear.
    Any feedback would be appreciated.
    Muzza80's Avatar
    Oct 2013
    Glasgow
    556
    If you want even drop then the Eibach front springs are probably the best option, they level out the car perfectly and the shipping costs to Aus will be way less as they're just a pair?
    2010 Audi S3 Sportback Black Edition TFSI Quattro
    Dec 2013
    142
    Yes I thought about that to as the s3 rear sits fairly low already stock. Have you used the eibach drop on the front? I want to drop the front by 25-30mm. Not sure if I'll be happy with just 20mm eibachs which I've come across.
    Dec 2013
    142
    Muzza!! Just read your build thread. I'm fitting 18" oem rs4 style wheels. Your cal looks low already in the pics and I guess the 19" rotors help that affect. Do you believe that 19" helped clear some gap?
    Muzza80's Avatar
    Oct 2013
    Glasgow
    556
    I've just ordered mine but not fitted as yet, that said there's plenty around who have and the drop is perfect, matches the rear 100%
    For example:
    Muzza80's Avatar
    Oct 2013
    Glasgow
    556
    Here's mine completely standard on the same wheels, you can see the front is a good bit higher.
    Dec 2013
    142
    Is that the 20mm eibach front only drop?
    Muzza80's Avatar
    Oct 2013
    Glasgow
    556
    Eibach Pro-Kit, yes.
    Hoesty likes this.
    Dec 2013
    142
    Yeah the 19" helped cleared comparing that pic with 18"s
    That's the same style wheels I'll be fitting.
    What's the ST reputation like in uk/eur? Thinking ST pack with the 20mm rear and 30mm front might be good with the 18"s
    Dec 2013
    142
    Bit of visionary wo lowering
    Dec 2013
    142
    This is my A3 sittin on kw v1 with 18"
    Hoping to get the s3 sittin like this with springs since the stock shocks can handle em.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Quote Originally Posted by Muzza80 View Post
    For example:
    Not a fan of that raked look... I understand why people do it tho, with the front arch being higher, but well prefer the flat look...
    interesting subjuct though... Mine are going on, week after next so, i'll be doing before and afters on the 25mm H&Rs
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
    Muzza80's Avatar
    Oct 2013
    Glasgow
    556
    Quote Originally Posted by S3_Jacko View Post
    Erm.... that's a pro-kit drop, perfectly flat all round, same gap front and rear......?
    Edit: Oh are you talking about the black one above?
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    Hey buddy Im running H&R springs all round and I can confirm it gives a totally equal drop. I wouldn't be a fan of installing just front springs, that's just weird in my own personal opinion and would wreak havoc with my OCD lol.
    Here is a side on phone pic of my s3. Sorry for the bad quality.
    Hope this helps mate.
    Alex C and Hoesty like this.
    Audi S3 8P3 / REVO Stage 1 / REVO Ceramic Intake / NGK Iridium Spark Plugs / LOBA HPFP / Philips Diamond Vision 5000k Fog Light Bulbs /
    KW V3 Coilovers / Team HEKO Wind Deflectors / Bridgestone Potenza S001 92Y Tyres / Complete LED Bulb Conversion (int' + ext') / Ashtray Delete /
    TTS Engine Cover / Alpine 928r Multimedia Station (8in screen) with integrated Bluetooth, Sat Nav etc / Ross-Tech VCDS Owner.
    Dec 2013
    142
    S3 Jacko, I'm confused what you are referring to by raked look? Some neat before and after pics would be great.
    S3 trev thx for sharing the pic and info. You drop 25mm all around? I'm with you on the OCD bout not doing rears and only fronts, although I can see where Murray is coming from as the rear is fairly low stock. Are you happy with the handling and look?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,368
    I'm also not a fan of negative rake(front end higher than the rear),but also not a fan of dropping the car too far.
    If you drop much more than 25-30mm,there is a bit of a risk of bottoming out over bumps at speed,and I've seen some real comedy examples of that,from cars so low that they simply can't drive quickly on a normal road.
    Here's mine.....dropped by about 25mm,on kW Clubsport suspension.
    Feb 2014
    12
    For example:
    Is this with the Eibach springs , as that looks perfect to me , ordered some 30mm drop eibach's last night for mine
    Dec 2013
    142
    Real nice Alex! The local guys who fit springs coils etc said the same thing you just said about bottoming out. One pot hole or bump could really cost ya, so he recommended KW v3s. *** costly so might just keep as is for a while. Also mentioned eibachs just on front won't be good for handling. Was so close to ordering em to.
    Alex are yours coilovers? Club sport different from the Variant series?
    S3Alex likes this.
    Dec 2013
    142
    Quote Originally Posted by Ian-speedy View Post
    Yes eibach pros on the front only as muzza mentioned. 20mm I'm certain.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,368
    Quote Originally Posted by Hoesty View Post
    Hi there...thanks.
    The kWs are coilovers,and have a wide range of bump,rebound and height adjustments.
    If you can wait,and buy them,they are a good investment...!
    The pic below is the Clubsport front above,with the v3 damper below....
    And one of the Clubsport on it's own....
    Aside from internal differences,the outside changes are adjustable topmounts,and linear rate springs,which are more suited to track use perhaps,whereas the v3's and others use more comfortable variable rate springs.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    Hey guys
    Personally I prefer the stance from the ST by KW springs.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    Yeah mate 25-30mm. Not sure I never actually measured lol. But think its 25. I am happy with the look but not the handling, as I am still running on the standard dampers, which generally isnt advised. I plan to buy coilovers this week (KW V3's possibly) so I will have these springs up for sale if you are interested.
    Quote Originally Posted by DPM View Post
    Will be ordering from yourself this week hopefully Damian. Just deciding between the KW V3's an the Billy B16s.
    Dec 2013
    142
    Sounds like I'll have to do some
    overtime to get these KW V3s to haha. Maybe V1s as I'm happy with them on my A3. Thx for honest opinion on the handling Trev.
    Will be worth the wait, but just hate waiting. :\
    Damian I reached out to you via email and thought id get some feedback from the people also. The option of the ST 20mm rear and 30mm front package sounds ideal. Just worried about the feel of the ride. If only I could try em out. Need an embassador in Oz? Haha
    s3_trev likes this.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Apologies for confusion guys for using that pic... Dont like higher arch gap at front... Front higher, negative rake look or positive look like you get on a lot of A3s
    Same arch gap, nice and flat....
    Need to really stop writing posts when tired... Like now ha
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Quote Originally Posted by s3_trev View Post
    This looks perfect to me... White 1 still looks as if it has a bit of forward rake, i.e nose down... Arches are cut higher on fronts than rear... Like the skirts to sit perfectly flat not pointing in either direction...
    Just my personal preference
    s3_trev likes this.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    This looks perfect to me... Black 1 looks like negative rake
    s3_trev likes this.
  28. #27
    Dec 2013
    142
    I know what you mean now. I dropped the front 10mm more after the pics were taken on the black a3 and it looks much better now. Trevs looks perfect.
    s3_trev likes this.
  29. #28
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    My old one on 25mm H&Rs and CHs.
    S3_Jacko, Kelza, s3_trev and 1 others like this.
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
  30. #29
    Muzza80's Avatar
    Oct 2013
    Glasgow
    556
    Before you go discounting the eibach's completely because someone told you it wont handle good with just front springs....
    The pro-kit is designed purely to take up the arch gap difference at the front whilst retaining the OEM spring rates, lets face it do you really want stiffer springs than standard, they're pretty stiff as is?
    Eibach know their stuff, they wouldn't sell miss-matched springs that would ruin the handling lol
    Hoesty likes this.
  31. #30
    Dec 2013
    142
    Pls give us some feedback once you fit em Murray! Seems like many ppl go H&R for springs. Havnt heard much feedback for eibach fronts only. The guys who told me are full track day heads and always recommend coilovers lol. Ballin so hard.
  32. #31
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    That's a nice choice to have to make!
    s3_trev and Hoesty like this.
    DPM Performance
    T: 01207 561606
  33. #32
    Jul 2011
    Not Disclosed
    483
    Don't forget that by just lowering the front, you're altering the balance of the car affecting understeer, turn-in, dive etc.
    I've recently fitted Eibach Pro-Kit front uprated springs, no complaints here as it's greatly reduced understeer, sharpened up turn-in and given a more positive feel even for aspects like braking.
    Hoesty likes this.
  34. #33
    Dec 2013
    142
    Thanks for sharing batch
  35. #34
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    Hoesty, I have just bought the KW V3's from DPM performance. I will inform you of what I think of them once installed and set up
    S3Alex and Hoesty like this.
  36. #35
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,368
    I think you'll be pleasantly surprised.
    It's worth spending a fair bit of time getting the bump and rebound settings to what you're happy with,and that does make a lot of difference even over the factory settings.
    Hope you like the results.
  37. #36
    Dec 2013
    142
    That's boss!
    I bet they'll be too damn good.
  38. #37
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    Thanks guys looking forward to getting them.
    Hoesty likes this.
  39. #38
    Dec 2013
    142
    If your H&Rs want to go on a charity run, let me know haha
  40. #39
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    Haha. Il wait till im happy with the KWs then sell them on. Will prob have to go local though due to the weight of them and the fact I live in NI.
  41. #40
    mechanic69's Avatar
    Mar 2007
    386
    Quote Originally Posted by batch View Post
    I can vouch for this, front end feels a lot more planted over stock spring height.
    S3 - Sprint Blue BE [MY11] My Build Thread
    Options - Satnav, Bluetooth, MFSW, Privacy Glass, Nappa Leather
    Mods - Bluefin Stage 1, DV+, Revo Race CIA, Cruise, TPMS, Bilstein B8s, Eibach Pro Kit, H&M Spacers, Exclusive Leather Trims
    Future - Downpipe sports CAT, HPFP, Stage 2+, ALK, ARB, 2nd Mortgage
  1. Replies: 13
    Last Post: 15th June 2005, 21:30
  2. Powerflex replacement bushes and lowering springs for a4 2.6Q
    By RICHARDJC in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2005, 00:00
  3. how easy is it to swap stock springs for aftermarket springs?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2005, 10:26
  4. Springs for S3
    By ImS3ola in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 08:02
  5. Rims and Springs for 90
    By prober730 in forum Handling
    Last Post: 15th February 2004, 23:14
