EM TuningAH Fabrications
Results 1 to 8 of 8
Thread: Lumpy idling
    Feb 2014
    Visit Jord159's Instagram Channel
    Lumpy idling
    Hey guys, I have a 2.0 tdi 140bh and when it's idling it seems to be very lumpy and judders but then when I give it some revs it goes away. I had it serviced today and the fuel filter was filthy! So we cleaned the cylinder up so all the dirt/grime was gone and changed the filter and it's still the same. What could be causing this juddering? Any advise would be great! Thanks!
    SmithyAG's Avatar
    Dec 2013
    Manchester
    355
    Follow SmithyAG On Twitter
    Try searching, it's been covered a lot.
    They all seem to do it to some extent or another!
    Feb 2014
    I done a bit of searching and some say injectors and some say engine mount or flywheel. But by looking at how dirty the fuel filter was today got me thinking it could be the injectors being full up with dirt or one of them might be down. So that's where i'm stuck.
    SmithyAG's Avatar
    Dec 2013
    Manchester
    355
    If its flywheel its normally a ryhtmic steady judder.
    Injectors can be ultrasonically cleaned and some people report improvements. Injectors are normally less of a rhythm than flywheel, mine judders for a secnond then nothing for a couple then judders again.
    Feb 2014
    Yeah mine does that, it feels like one of the injectors isn't work properly or if at all. its fine up the revs, its just idle.
    SmithyAG's Avatar
    Dec 2013
    Manchester
    355
    If it's fine throughout the range then the injectors are most likely still serviceable. They aren't an easy item to remove and re fit though.
    Ideally you want them taking out and cleaning at a diesel specialist.
    Redex and similar additives don't really make a noticeable difference , especially on PD engines.
    Nov 2013
    49
    If it is fitted with the hydro engine mounts and the fluid has leaked this could cause erratic idle had mine done on my a6 felt the difference after
    a scan will pick it up
    Dec 2013
    25
    Mine does this. It led me to have my flywheel changed (that and poor starting and a metallic rattle) and imagine my disappointment when the car came back with new flywheel and new starter motor and it still vibrates.
    Sometimes barely noticeable, other times a fair shudder (oddly I'm convinced its after a motorway stint and pointing uphill on an exit slip).
    Would love to find a fix as it does my head in.
    At least being a dsg if I leave it in "D" or "S" it's almost imperceptible.
    Audi S3 2.0tdi DSG S-Line
    8P1 - 2005
  1. FSi-Lumpy idling and starting problems
    By Aldo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2006, 16:00
  2. First impressions & lumpy idle when cold?
    By rowansbank in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2006, 09:31
  3. Lumpy Idle - coolant sensor?
    By recomdos in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2005, 09:09
  4. Fixed Lumpy Idle.
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2005, 21:41
  5. Lumpy idle 2.0 TDI
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2005, 12:28
