EM TuningBadger5
Results 1 to 40 of 40
Like Tree7Likes
  • 1 Post By Mr_Sixx
  • 1 Post By DazNoonan
  • 1 Post By S Liner
  • 1 Post By 964kevin
  • 1 Post By lgooch
Thread: A3 2010 Sportback Black Edition Bluetooth
    Feb 2014
    34
    Maybe an easy one this... Will this car be fitted with Bluetooth as standard? It's got standard headunit.
    I'm picking the car up tomorrow... If it's not standard is there a way to check for it and also how much roughly would it cost to get something fitted?
    Mr_Sixx's Avatar
    Stationary
    Aug 2007
    In the sticks of Derbys & Notts
    169
    Mines got it fitted - best way to check, go & do a Bluetooth search & you'll find one called Audi_hv or similar! this should be your Bluetooth connection!
    2012 A3 Tdi 170 S Line Black Edition
    Feb 2014
    34
    Quote Originally Posted by Mr_Sixx View Post
    Was it part of the standard equipment do you know or will it be some have it and some don't?
    Also so when I pick it up start the car the search from iPhone and see what happens?
    Mr_Sixx's Avatar
    Stationary
    Aug 2007
    169
    Dunno if it's part of the standard equipment, I think it was on the BE's.
    Yep do the scan from your iPhone, mine worked a treat - not sure of the pairing code though, it may be 0000 or 1234, the manual will tell you
    DazNoonan likes this.
    Mr_Sixx's Avatar
    Stationary
    Aug 2007
    169
    Just checked, mobile phone perpetration - low is part of the std spec for the BE's, you should be good to go!
    Jun 2010
    East Manchester In the Hills !
    677
    Work colleage has a 10 plate BE and no Bluetooth. Not sure when it became standard
    Feb 2014
    34
    Hmmm some confusion then... Would be good to have to. I wonder if it became standard the sametime they changed the wheels etc...?
    Jun 2010
    677
    He has the old style 7 spoke alloys in titanium. Also his steering wheel didn't have a silver ring in the insert around the Audi badge.
    Mr_Sixx's Avatar
    Stationary
    Aug 2007
    169
    I'm sure the Audi brochure I looked in was for 2011 model year, it certainly wasn't earlier than that. Best bet, pop out n have a scan
    Feb 2014
    34
    Quote Originally Posted by lgooch View Post
    Yeah one I've gone for has the same wheels...
    Feb 2014
    34
    Yeah like I said im collecting tomorrow... Also know to scan for audi etc... So thanks for the info.
    Mr_Sixx likes this.
    Mr_Sixx's Avatar
    Stationary
    Aug 2007
    169
    No problem - I'm not as clued up as the guys on here, just know how mine works old vw's are more my thing!
    Jun 2010
    677
    You might have been lucky and whoever owned it could have specified it on the build. Not too expensive to retrofit if you need it anyway. The Audi system is very good indeed. Better than any aftermarket solution i have used in all my cars
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Jun 2010
    677
    This is MY2012. Mr six has bought a 2010 model. I have a 2012 model car and it has Bluetooth as standard as per your bulletin. He does not even have the same wheels
    Mr_Sixx's Avatar
    Stationary
    Aug 2007
    169
    I hope mines not a 2010 :o mines the 2012MY with Bluetooth & the rotors as standard - its Daz that bought the 2010
    Jun 2010
    677
    Ah. Sorry doing all of this on an iPhone ! Apologies. Comment still stands though
    Jan 2012
    57
    https://www.audi.co.uk/about-audi/la...e-audi-a3.html
    No bluetooth. Was also only available in 5 colours when it first come out in 2009?
    Jun 2010
    677
    That's all correct. I started looking or my BE when 11 plates came out and they started fitting the rotors half way the through MY11 if I recall. At this point they also started fitting BT low and I ended up opting for BT high which includes the cradle in the arm rest and voice control
    OP could be lucky. Only one way for him to find out
    Feb 2014
    34
    Thanks for all the info... will do as you said tomorrow when I have started the car and search for Audi - Hopefully I am lucky!! If am not for any reason how do I go about getting bluetooth fitted (audi genuine one) and roughly how much would it cost? I know I won't be able to fit myself as I'm not really good with things like that...
    Jan 2012
    57
    Bluetooth upgrade
    Or if your buying the car from an Audi dealer i'd haggle with them to fit the OEM bluetooth for you!
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    728
    Bluetooth was deffo optional until 2011 when it became standard.
    Mine is a MY11 60 plate BE with rotors and it didn't have Bluetooth
    Audi A4 BE 2.0 TDI 177 Quattro
    964kevin's Avatar
    98
    my 09 BE had bluetooth as standard, I did not spec it, it is also standard on my 11 plate, again I did not spec it.
    K
    RobbieWebs likes this.
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    728
    Hmm strange that as I found old brochures and it said it was an option and not standard ...
    Jun 2010
    677
    Sometimes already included as part of a tech pack or something. I.e. You ask for sat nav and it gets thrown in. Just a thought I could be wrong
    Jan 2012
    SW London
    794
    Make sure u search within the first few mins of starting up the car otherwise it might not pick it up.
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
  28. #27
    Feb 2014
    34
    Quote Originally Posted by Sidhu88 View Post
    Will do... Thanks for the heads up.
  29. #28
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    728
    Well does it have it or not?
    Lol
  30. #29
    Feb 2014
    34
    Just got home from collecting it and nope no Bluetooth installed.
  31. #30
    Jun 2010
    677
    Damn. Trip to NHN for you !
  32. #31
    Feb 2014
    34
    Yeah already emailed him for some prices... I do need the Bluetooth so will have to get it sorted.
  33. #32
    Jun 2010
    677
    The OEM BT is excellent as well. Worth the extra money over an aftermarket kit IMO
  34. #33
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    728
    How are u enjoying the car?
  35. #34
    Feb 2014
    34
    Loved the drive home Robbie. Got home around a couple of hours ago had some food then just realised I must go for another drive so just got back. Love it...
  36. #35
    Jun 2010
    677
    What model is it. Diesel or S 3
  37. #36
    Feb 2014
    34
    Diesel 170
  38. #37
    Jun 2010
    677
    Nice ! I just wish I had those extra horses
  39. #38
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    728
    Glad ur enjoying the car
    I'm in the same boat as Igooch, I wish I had the extra horses.
    Nothing a remap won't sort out tho
  40. #39
    964kevin's Avatar
    98
    Possibly, my first 09 did not have anything extra, my 11plate has a tech pack, auto lights, cruise, windscreen wipers etc.
    I didnt know this was installed until I read a thread here 3 years ago that mentioned doing the bluetooth search when the ignition was first turned on......
    Kevin
  41. #40
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    728
    I still haven't fitted it to mine as I'm not in the car long enough.
    Nice thing to find tho if u didn't expect it
  1. 2010 A3 Black Edition - RNS-E with Bluetooth Audio Streaming???
    By Bailey_36 in forum In-Car Entertainment
    Last Post: 7th August 2013, 15:50
  2. AUDI A3 1.8 TFSI SPORTBACK BLACK EDITION *VERY LOW MILEAGE* (2010/10)
    By gypsymoth in forum For Sale/Wanted - Audi Cars
    Last Post: 2nd October 2012, 15:26
