    Dec 2013
    6
    A3 TDI 170 - Hesitation when boosting
    Hi Guys,
    My car has recently developed a little problem. When I accelerate the boost starts kicking in, hits a flat spot then continues to pull. Also it just doesn't feel as quick as when I first got the car a few months ago. The car idles perfectly, good temps and no smoke at all. Sounds smooth as silk when revving whilst stationary.
    I never let it run low on fuel.
    I had the cam belt and injectors done about 3 weeks ago. Now I don't know if its me but the problem only seems to have started since this.
    Please help guys, its killing me that my beloved car is being problematic.
    May 2013
    163
    Have you checked for any faults on VCDS?
    Dec 2013
    6
    Forgot about this thread.
    Literally minutes after my post, I had to take the car out and about 30 seconds down the road the DPF light popped up on the dashboard. Took the car for an hour drive, keeping it above 2k RPM and light cleared. All seems good now but seriously considering DPF removal and a custom remap.
  1. Possible boost leak? - Hiss / Air escaping when turbo spools up (2.0 TDI 170)
    By The_life_pursuit in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th December 2013, 12:00
  2. TDi 170 - hesitation at 3500 rpm in 4th - oil under bonnet - Tandem pump?
    By Cossie_boy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th July 2013, 22:17
  3. TDI 170 'Hesitating' under acceleration
    By Henry1302 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th May 2013, 19:44
  4. Hesitation when revs hit 2800+ - A3/8P 170 Sportback 57 plate TDi Manual
    By kinginter in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2013, 00:15
  5. TDI 170 mostly white smoke and bit of blue at idle, clears when revved
    By swanbon in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th October 2012, 13:22
