JMB RetrofitsBadger5
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Phil-1
Thread: Rear shocker boot trim removal.
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,114
    Can someone please help me. I want to check the top shocker mount.
    How do you remove the trim in the boot to get to the top mount?
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagust.co.uk
    E-Mail:info@philseagust.co.uk
    Mar 2011
    Cleveland
    996
    Here you go:-
    VW AUDI Forum - VWAF
    Can't see any shocker tops? Under the wheel arch?
    Feb 2011
    Plymouth
    1,147
    Top of the shock absorber?
    It's mounted from the top of the rear arches. You can't see it from in the boot.
    2 x 17mm bolts attach it to the car, but you've gotta pull a bit of the arch liner out the way to see them.
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,114
    Thanks guys. I'm trying to get to the bottom of a suspension knock/noise, I have had the spring and bushes checked last week when it had its MOT. The noise sounds like it's coming high up. Could something else be loose behind the boot trim?
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,114
    Update:
    Just been out checked the shocker mounting and all is good no leaks or anything. I then looked at the under suspension plastic tray, I had noticed that it was a bit loose, anyway had a close look and its broken it has several cracks and possibly a clip missing. Took it for a quick test and the noise has gone. Result😃😃
    TillA likes this.
    Mar 2011
    Cleveland
    996
    Quote Originally Posted by Phil-1 View Post
    Update:
    Just been out checked the shocker mounting and all is good no leaks or anything. I then looked at the under suspension plastic tray, I had noticed that it was a bit loose, anyway had a close look and its broken it has several cracks and possibly a clip missing. Took it for a quick test and the noise has gone. Result������������
    Great! If only all repairs were as easy............
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,114
    Quote Originally Posted by fangio View Post
    Thanks mate.
    It's been driving me mad for weeks, today was the first time I have had the time to look at it. Just waiting for a replacement price now.
  1. Avant drivers side boot trim removal? ?
    By Tim@G in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th July 2013, 13:48
  2. Boot trim removal
    By Andy27168 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th April 2013, 19:29
  3. Boot trim removal !
    By Stubie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd August 2012, 22:06
  4. B6 cab boot trim removal
    By JonnyO in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th May 2011, 10:36
  5. S3 rear quarter panel trim removal
    By NWMark in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2006, 09:08
