What is it that holds the rear tailgate lights in? I have changed the main units they have the usual obvious nut behind but I cant see what is holding the tailgate units in
Cheers for that got them changed but I did drop one of the big plastic nuts down the back off the trim when changing the main units cant see how to get at it
thats right mate a bit scary but I copied original long code just incase and then made changes and worked great first time so I was well chuffed cheers again for your advice mate I just need to order a new plastic nut and gromet , I put a normal nut on for now but the plastic one is long and easier to get at and theres a bit of movement with the missing gromet
