Badger5Sky Insurance
Results 1 to 17 of 17
Like Tree5Likes
  • 1 Post By s3_trev
  • 1 Post By Granta
  • 1 Post By batch
  • 1 Post By s3_trev
  • 1 Post By batch
Thread: Question s3 clutch
    Nov 2013
    South lincs!
    20
    Question s3 clutch
    Hi
    i have a completely standard 2007 s3 and the clutch is on its way out so I'm nursing it until I have enough pennies to buy a new one.
    so what do I buy??
    Do I keep a oem type one? Which everyone states is a bit poo and weak.
    or do I go for a performance clutch spend a lot more but in the long run lasts longer etc I might do a remap later on. Not sure??
    i have a quote from a local specialist £1500 job lot.
    this is for;
    - 6hr labour (quite a lot of work apparently ,subframe down, gearbox out, realignment etc)
    - Sachs performance clutch 400lb/ft kit inc single mass flywheel 02Q (this is £940)
    - clutch release bearing and slave cylinder - luk
    - 6 flywheel bolts 02M 6spd
    - 6 clutch cover bolts
    So is this quote expensive? Or reasonable?
    is this clutch a decent one? There's so many to choose from Im confused?
    thanks Sam
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    625
    Could maybe be about right mate if you are paying a specialist to do it. At least then it should be done right. I must have the only standard clutch S3 in the country lol touch wood.
    chilly likes this.
    Audi S3 8P3 / REVO Stage 1 / REVO Ceramic Intake / NGK Iridium Spark Plugs / LOBA HPFP / Philips Diamond Vision 5000k Fog Light Bulbs /
    KW V3 Coilovers / Team HEKO Wind Deflectors / Bridgestone Potenza S001 92Y Tyres / Complete LED Bulb Conversion (int' + ext') / Ashtray Delete /
    TTS Engine Cover / Alpine 928r Multimedia Station (8in screen) with integrated Bluetooth, Sat Nav etc / Ross-Tech VCDS Owner.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,793
    Absolutely no more than £1000 inc parts and labour.
    I had mine done at VW main dealer for £800 when I had my 09 S3 manual.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Aug 2013
    Surrey
    135
    Quote Originally Posted by s3_trev View Post
    Me too mate and I mapped it 6 months ago!
    s3_trev likes this.
    XFi
    Jun 2010
    344
    My clutch is on its way out and I have been quoted £1240 fitted. £880 for a Sachs up rated clutch and SMF including everything that's required. £360 for a days labour at a specialist.
    Jul 2011
    Not Disclosed
    483
    Quote Originally Posted by Granta View Post
    And me! Touch wood. Although apparently later S3s had a decent clutch plate in anyway?
    s3_trev likes this.
    Jun 2013
    326
    If your planning to start modding it then I would upgrade cause once u start you will want more and more hahaha I wanted map then it's not turned out to be stage 2+ soon lol
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    625
    Quote Originally Posted by batch View Post
    Hmm id love to know for sure. Never done hearing people complain about how bad the are but mine is fine running about 330 bhp.
    batch likes this.
    Jul 2011
    Not Disclosed
    483
    Where are you based mate?
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    625
    Northern Ireland mate. Thats if you were talking to me and not the OP lol.
    Jul 2011
    Not Disclosed
    483
    I was talking to you Trev yeah, shame you're so far away! Always nice to meet new owners but seem to be few in my area!
    s3_trev likes this.
    Nov 2013
    South lincs!
    20
    Quote Originally Posted by mjr901 View Post
    £1000 is that for a performance Sachs clutch?
    Would a 400lb/ft clutch take a remap comfortable?? That's the other thing I thought was a bit low?
    Thanks for the replys!
    XFi
    Jun 2010
    344
    Quote Originally Posted by Sammyfat View Post
    I think he's on about a standard clutch, flywheel and labour for less than 1k. The Sachs clutch and flywheel is almost 1k itself without labour!
    On stage 1 you'll be expecting around 300/310lb Ft so it's good even for stage 2+
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    The Sachs is generally quite conservatively rated,and if run in properly,and treated with some respect(i.e.no drag starts etc),it can manage up to 440lbs,as that's where my Sachs eventually started to slip at.
    If you don't bed it in over around 500 miles or so,or you enjoy drag style starts,then it will give up way before then.
    The Loba/SMF clutch will cope with more abuse,but after that,you're looking at systems which can be a bit beyond what you're after both performance wise,and cost wise.
    XFi
    Jun 2010
    344
    Quote Originally Posted by S3Alex View Post
    The Loba item is the Sachs though minus a different flywheel that is apparently more quiet. I'm torn between the Loba+Sachs or just the Sachs.
    Nov 2013
    South lincs!
    20
    I don't think I will be doing many drags starts to be honest. Haha.
    What's involved in the bedding in process ? Keep off boost!
    What clutch are you using alex in your stage 4 monster ?
    I was told the smf was nearly unnoticeable to the dmf and lighter so revs slightly easier.
    Sep 2012
    44
    Me too! Baby it don't batter it, gotta be smooth and slick with the clutch.
    Past Motors
    Golf Tdi
    Fiesta Zetec S
    350z
    Current Rides
    S3
    A3 TDI Quattro
  1. Question about clutch.......
    By vw754 in forum Parts Requests
    Last Post: 14th December 2009, 18:21
  2. Quick clutch question please...
    By S3Si in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2006, 08:03
  3. Another newbie question - Clutch
    By eimajmong in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2005, 17:08
  4. Clutch Question
    By necroeire in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2005, 21:42
  5. Clutch Question...
    By imported_WatchMeFlyBy in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th September 2004, 21:21
