Volks AutosMonster Motorsport
Results 1 to 27 of 27
Like Tree1Likes
  • 1 Post By @udi A3
Thread: No on-board computer? it seems blank also vibration at 70-8mph 6th gear
    Jan 2014
    27
    hi all, I have 2 issues with my 2006 A3 2.0 tdi SE, 6 speed manual
    1. The trip computer is blank. The only light appears is when a door is open and a small dim red light appears showing the door is open, at the centre of the screen. I also do not have the reset button on the bottom of the wiper stalk.
    2. There is vibration SOMETIMES when i'm travelling at round 70-80mph on 6th gear on the motorway. although I am not entirely sure if it's only if i'm on 6th gear. Have some vibration at stand still, on idle too.
    What gives?
    May 2013
    245
    Has the trip computer ever appeared? Is it possible you don't have the DIS? Have you bought the car recently?
    Jan 2014
    27
    Quote Originally Posted by DriverN00B View Post
    No, it has never appeared. Only time anything comes on it when a door is open and that small red light indicating a door is open, turns on. I only bought the car in December last year.
    Sorry, but what does DIS stand for?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Driver Information System I think.
    Is it possible to have the DIS cluster but no stalk?
    A picture of the cluster might help?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Jan 2014
    27
    I will try to get a picture of my cluster and stalk this afternoon during my lunch break. But I have seen on other forums, that apparently there is a reset button on the wiper stalker for the DIS. I have no such button on mine.
    Mar 2012
    356
    I think we've had this before - not all of the later cars (and poss some earlier ones) have DIS, looks like yours is one.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,062
    If you dont have the button, its likely that you do not have the DIS on your car.
    There is a button on the bottom of the stalk that switches it on and off.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    This is a 8P stalk with DIS
    Jan 2014
    27
    Pretty crazy to think a premium hatchback doesn't come with DIS! I mean my car even has cruise control!
    Jan 2014
    27
    Quote Originally Posted by ScottB5 View Post
    No I definately do not have that reset button on mine.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Did you not check when buying? It's fairly obvious when you've got no information coming up on the little screen in the cluster.
    You can have it retrofitted I believe. I thinks it's just a new stalk and some VCDS coding. Speak to NHN
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Jan 2014
    27
    Quote Originally Posted by A3Kent View Post
    I had a quick browse on ebay. The wiper stalk with the reset button (same ones used on VW and skoda too) is only around £10-£20.
    What would be the approximate cost for the coding?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Beer tokens if you find a local member with VCDS who's willing to do it.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Quote Originally Posted by plasma View Post
    Drop NHN a PM mate or have a look at the VCDS map and see who's local to you who has VCDS.
    May 2013
    245
    I think there's more involved than just getting the stalk and doing the coding, here's a link to another forum NHN posted on with regards to it, should give you an idea of what's needed.
    Retrofitting DIS to A3 2008 SE
    May 2012
    RETFORD, NOTTS
    1,748
    Defo more that just VCDS coding im afraid. I have all the tools and access to second hand red or white type desel clocks should NHN be unable to help.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Are you sure?
    Everything I've read says VCDS is all you need.
    SJ
    Jan 2013
    75
    The little red door open warning is a good indication that the cluster doesn't have dis. A closer look at the center display panel will let you see the outlines of all the other static warning lights that are there, if you can see those then it's definitely a new cluster required if you want to have dis.
    Jan 2014
    27
    Quote Originally Posted by SJ View Post
    Thanks for the info. So essentially if I see the outlines, I need an entirely new cluster? I thought if I cannot see the outlines then I would definately need a new cluster?
    Jan 2014
    27
    Just spoke to NHN and as my car already has cruise control, then DIS is possible and I would not need to change the cluster. All I need is the wiper stalker. Anyone has a part number for this?
    SJ
    Jan 2013
    75
    That's correct, I'll try and attach an image of a basic cluster with no dis. On that cluster when the warning lights are off you can still just about make out where the warning lights are.
    This is as opposed to the clusters with dis where these lights are not there but are instead displayed on a LCD display, hence when its off it appears completely black.
    Jan 2014
    27
    My warning lights are all on the cluster (next to the rpm dial) not that centre screen that shows the door open sign.
    SJ
    Jan 2013
    75
    Sounds promising. Here's a non dis cluster with all the lights illuminated to make them nice and obvious. You'd be able to see the outline of all the warning lights in the center as you can for the ones by the dials. If you can't see any there then you should be able to enable dis to some extent by just coding uploadfromtaptalk1392303155402.jpg
    May 2012
    RETFORD, NOTTS
    1,748
    Are you sure?
    I was assuming a non dis dash, and new cluster needed. If in fact the dash is a dis, then vcds will do the job.
    ScottD3 likes this.
    Jan 2014
    27
    Quote Originally Posted by @udi A3 View Post
    So all I need is the correct wiper stalker and the coding right? Can anyone please provide me with the part number? or a link? thanks
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Not at the moment but if you ebay it there seems to be some on there.
  28. #27
    May 2013
    245
    Plasma does your current dash look like the one posted above by SJ?
  1. On board computer
    By nicks3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th July 2005, 15:41
  2. On board computer display
    By rusty in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2004, 13:55
  3. On Board Computer
    By doddym in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th March 2004, 17:54
  4. TRIP, DIS, On board computer.
    By Gambba in forum General Technical / How To
    Last Post: 8th April 2003, 21:52
  5. On board computer trying to scare me?
    By dandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2003, 02:11
