Badger5AH Fabrications
Results 1 to 10 of 10
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    EGR blank - with hole or without
    About to purchase an EGR blank, should I go for the one with the hole or without?
    Is there much difference apart from the EML coming on?
    Chris
    2008 Audi A4 B8 3.0TDI Quattro S-line (240) in Aruba Blue
    Feb 2012
    Chelmsford Essex
    22
    So am i right in thinking that you fit a blanking plate with a hole in it ? How big is the hole ? I have got a solid blank plate in mine so just have to live with the light on
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    I tried the blanking plate with out the hole and my light came on,my mgp went down and i was down in power slightly so i when i got a stage 1 remap i asked them to turn off the egr to which they told me that it cant be turned off just turned down,so i have got one with a hole and the light is off and back to normal.
    I know people is going to say that it can be turned off but i am just going by revo tunning told me.
    Feb 2012
    Chelmsford Essex
    22
    Funny you should mention it my MPG is not the best and i hadn`t even thought about the blanking plate . After having some turbo issues i just stuck the plate in , maybe i should take it out again
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    It cost me £3 from vw garage and it seems not to be stuttering,when i put the blanking plate in, i gave the egr a good clean in my parts washer put it all back together and the light would not go out after reseting it,i must of got cleaner in the vacume side and didnt like it so £40 later all works fine and no light
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    I've fitted one without a hole and the car is running loads better. Tempted to drill a hole in it to prevent the EML coming on.
    Would the car still run smoother if the plate had a hole in it? Or is it best to keep it blanked completely.
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    You'd likely still get the EML light on with a hole in it, the ECU 'knows' what 'should' be passing through the EGR and if the figure (requested and actual) are however much different it'll throw the light
    Get the EGR blanked, remove the cooler & all pipe work and get it remapped out properly - your engine will thank you for it
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Feb 2014
    33
    I blanked it and put a blank in the vacuum pipe going to the EGR, no light and runs perfect. =D
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    Quote Originally Posted by Iain-A6 View Post
    What year is your car?
    With mine been a 2008 it has the electronic module and not a vacuum. Think the only way round it is to get it mapped out.
    Can't believe how much different the car feels though, very smooth, like brand new.
    It's amazing how much crud you find in the EGR, Inlet (and probably turbo) - not good for the engine.
    When I get a bit of spare time I'm going to get it all cleaned out and put the blank back on the EGR.
    Feb 2014
    33
    Mines old 2000 so it's vaccum. EGR just covers everything in carbon.
  1. Performance probs after fitting EGR blanking plates
    By tuffguy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th June 2014, 22:52
  2. A4 B5 Facelift front bumper with holes for headlight washers
    By Bunsen Honeydew in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2011, 22:26
  3. egr blanking
    By r3stu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th May 2010, 22:43
  4. Parking Sensors with holes
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th May 2009, 12:22
  5. EGR Blanking cap
    By james0808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2006, 14:45
