AH FabricationsBadger5
    Jul 2013
    2007 Audi S3 - Erratic Idling
    Hi guys! I think I have 2 separate issues with my 2007 Audi S3, an emissions one and an idling one. Been a great car with no problems at all until a few weeks ago.
    I have read the thread about erratic idling and I will change the Breather Control Valve but wanted to come on here first to see if mine was a different issue. The part no Audi gave me for the PCV ended in R which he said was the latest one. Is that true as some people's end with N, K, F etc?
    I have these fault codes if anyone recognises them or know how to fix them.
    01089 - EVAP Emission Contr.Sys.Incorrect, Purge Flow
    01287 - Idle Control System, RPM Higher Than Expected
    Cheers, Tom.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    For the idle fix: (01287)
    Latest revision is now indeed 06F 129 101 R
    Previously the part ended with F, K, L, N. (now R)
    For the evap fix: (01089)
    My money is on replacing N80 valve and check adjoining pipes for blockages.
    You may find the problems are interlinked. They're both Vacuum problems, so curing one may cure the other.
    PCV valve is the first go.
    Clear faults after changing it, go for a drive, rescan, go from there.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    bomasspot's Avatar
    Apr 2011
    Kent
    40
    Agree with mjr901-go for replacing the PCV valve first thing. Nine times out of ten it's that.
    Jul 2013
    Replaced the PCV and test drove it. No problems so far. Its was an intermittent fault so I'll test it all week and post if it fixed the problem and also if the Emission issue comes back.
    Jul 2013
    No idling problems at all now since replacing the PCV (which was very easy just 4 bolts and a couple of clip on pipes) and its been over a week, very happy.
    Have the car booked in to a garage for the emissions issue tomorrow. Will let you know what the outcome is.
    Thanks people
    Jul 2013
    Emissions issue was a charcoal canister/filter £50.
  1. 2007 Audi A3 170 TDI Quattro idle problem? Injector Recall done.
    By davsmith64 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2013, 12:14
  2. 2007 Audi S3
    By torres in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2006, 16:35
  3. Friends A6 Cuttiung Out and Erratic Idle
    By myrichdad in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th September 2005, 21:15
  4. erratic idle??
    By MickA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2005, 10:39
  5. Audi 80 1993 2.0l Erratic Idle... Help???
    By imported_stephens_aj in forum Classic Audi Forum
    Last Post: 28th July 2004, 21:44
