Badger5AH Fabrications
Results 1 to 8 of 8
Thread: EGR cooler
    Jun 2013
    6
    EGR cooler
    Hi folks,
    Got an engine management light on yesterday on my MY11 A3 2.0 TDI (41,000mls) and lost power.
    Booked in to Audi and left it with them, got a call same day saying its the EGR cooler, being done today 5 hr job apparently, just glad i've got 3 months Audi warranty left or was looking at a BIG bill.
    I've searched the net and can only find examples of this problem on older audis and the 1.6 TDI in skodas etc.
    Is this common in the 2.0 TDI CR?
    cheers,andy
    taffymanA5's Avatar
    May 2014
    Hi Andy just had a call from main dealer my 3.0 TDI 08 needs a new EGR valve....out of warranty gonna cost a big fat £795.32 fully fitted :-(((( like you couldn't find to much info on the web most of the stuff was a couple of years old......bit of a shock as only had it 4 months with 51k.
    Using Tapatalk
    Jun 2010
    East Manchester In the Hills !
    677
    I have had the same problem with a golf. Its all to do with not driving them as designed and lots of short journeys. The EGRs just clog and on the new CR engines you cant clean them like you could with the BKDs. they are also now tucked behind the turbo which means the sub frame has to be dropped, engine supported, exhaust off etc etc. Hence a 5 hours job.
    It would have been worse. you could have needed a dfp as well for a total bill of around £ 2K.
    Precisely the reason I have gone back to a petrol powered car. They are literally ticking time bombs. Have a look over on TDI club, there is a massive thread on them.
    matt66604's Avatar
    Dec 2013
    Aberdeen
    52
    I can confirm the egr cooler is a fairly common problem on A3 2.0 Tdi's and the 1.6's where it's mounted round the back and the A1's, some of them can leak internally but most commonly they sieze internally.. audi has released a bulletin about it.... also A4's, A5's , A6's , Q3's.. anything that uses the side mounted EGR cooler above the turbo...
    Feb 2012
    Birmingham
    137
    Quote Originally Posted by taffymanA5 View Post
    With that bill I would defiantly be looking at having it mapped out and removing it!!
    Jun 2010
    677
    But risking possible MOT failure.
    Feb 2012
    Birmingham
    137
    I've never heard of a diesel failing on emissions. I dont think they even stick the pipe in at my local mot station, ill check within the next week as it due :D
    Feb 2012
    338
    Diesel taken for a good run before MOT will rarely fail emissions.
    You wouldn't piss in your own glass of water so why would you leave the EGR in there? If/when mine goes wrong it's coming straight out...
  1. audi a3 egr valve and egr cooler delete
    By zaidar61s in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2012, 11:50
  2. lowering springs , shocks , tandem pump , egr cooler
    By tdi-man in forum For Sale/Wanted - Audi Parts
    Last Post: 25th January 2012, 19:02
  3. EGR cooler torque
    By prs999 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th November 2011, 10:04
  4. 2005 tdi EGR Cooler click
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th September 2010, 10:05
  5. Do 2.0TDI BKD EGR Coolers Really Leak???
    By Tonyc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st August 2010, 13:03
