Volks AutosSky Insurance
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By veeeight
Thread: Engine Oil Top-up - Advice needed
    37
    37's Avatar
    May 2013
    Area 51
    118
    Hi,
    So my 1.6 Petrol was on Long life oil (personally not a fan but that is besides the point).
    Driving back home and low engine oil light came on and needs topping up. Service is not due for another 3 months and MOT is around that time too.
    So my question is:
    - Should I top up Now and wait for service or should I just go for Full service?
    - If its top up, can you recommend good oil and how much I should top up (1 ltr?)
    Mr_Sixx's Avatar
    Stationary
    Aug 2007
    In the sticks of Derbys & Notts
    169
    if the oil light is on, it needs topping up regardless of time to the next service or risk it running out altogether, simple as. Top up should be however much it needs to get to the max mark on the dipstick!
    2012 A3 Tdi 170 S Line Black Edition
    prt57's Avatar
    Dec 2006
    243
    Add some top oil then allow it to drain through to the sump for a few minutes before wiping the dip stick clean then check the level. Repeat this until the level is correct and do not overfill. Check the manual to confirm where full is on the dip stick.
    Ch3tan's Avatar
    Nov 2013
    London
    43
    As above, top up now or just go for your service early.
    With regards to how to... run the engine for a few minutes idling on a flat surface. Turn off and let the engine cool for two minutes and then check the dipstick level by removing it, cleaning it and then plunging it and checking.
    If it's showing low then top up by no more than 500ml at a time and repeat the above to check the new level before adding anymore.
    2011 A3 140 2.0TDI Black Edition
    37
    37's Avatar
    May 2013
    Area 51
    118
    Recommendation for Engine Oil?
    Is this good?
    Ch3tan's Avatar
    Nov 2013
    London
    43
    Use discount code parts25 for 25% off at euro car parts. Audi use the Castrol edge stuff and that works out at 12quid after discount.
    Feb 2014
    24
    What happens if you go past the max mark about 3mm
    prt57's Avatar
    Dec 2006
    243
    Quote Originally Posted by aiwa_yamaha View Post
    I bought a TT 2.0 3 weeks ago and the oil was past the max by about 5mm. The car was booked in for a service and cam belt and I asked about it. The view was that with this amount over there was nothing to worry about. Just the week before they had had to drain a sump where the oil level sensor had broken and the elderly owner had over filled by about 3.0 litres as the sensor kept on indicating more oil was needed.
    Once drained out and sensor fixed there were no apparent lasting problems
    Jul 2012
    Cheshire/N Staffs
    1,371
    Reduced at Tesco:
    Ch3tan likes this.
    S3 8V 3DR DSG ACC ABS ADS AMI ASR ASS DAB DBW DIS DRL EBA EBD EDL EGR EPB EPS ESP GPS LED MFSW MMI PDC PSF RAC SDXC TFSI CO2 EEC OTR WTF OMG
    Feb 2014
    24
    thanks
    Jan 2014
    25
    asda have the 4L drum on offer for £30, reduced from £38
    37
    37's Avatar
    May 2013
    Area 51
    118
    Ended up buying from Lloyds motor spares for £35 4l (Only place close by). Didn't want to risk taking it out for a long drive!
  1. Oil Cooler Problem advice needed
    By galashan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th September 2013, 21:17
  2. engine management light on advice needed
    By daren in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th December 2012, 18:44
  3. engine problems advice needed
    By 20s on a tt in forum TT/TT-S/TT-RS Forum
    Last Post: 31st March 2008, 10:26
  4. Low Oil - Quick advice needed
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2007, 20:57
  5. Who said turbo needs Engine Oil?
    By godwine in forum General Chat
    Last Post: 6th November 2005, 00:02
