Monster MotorsportEM Tuning
    Feb 2014
    24
    Slight oil in coolant
    Found some slight oil in my coolant tank. Is this most likely going to be the oil cooler?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,161
    engine block or head gasket.
    Dec 2013
    Greens Norton Towcester Northants
    36
    Check if you have emulsified oil in the top of your rocker cover. If so probably head gasket.
    Apr 2013
    Aberdeenshire
    585
    Quote Originally Posted by judge View Post
    oil cooler maybe but not common
    Tonka Toy's Avatar
    Dec 2013
    Hertfordshire
    119
    Quote Originally Posted by aiwa_yamaha View Post
    Pressure test the coolant system or use the sniffer?
  1. help needed bout oil in coolant reservoir
    By Lex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th September 2010, 17:36
  2. Oil in coolant. Can't link to diagnostics. Oh ruddy hell...
    By Cornrow in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2010, 12:41
  3. Oil in coolant
    By Al@n in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th February 2010, 15:58
  4. slight oil problem
    By kevsn in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2008, 19:19
  5. Oil or coolant pump ? once engine switched off ?
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2007, 23:06
