JMB RetrofitsSky Insurance
Results 1 to 12 of 12
    Skittler's Avatar
    Redlined
    Jan 2006
    Wokingham, UK
    131
    3.2 - Any difference with Unleaded vs Super Unleaded
    Does anyone know exactly what the difference is in power in a 3.2 when using Super Unleaded (as recommended) compared to standard Unleaded?
    imported_S_Line
    Re: 3.2 - Any difference with Unleaded vs Super Unleaded
    Hi mate looks liek you have the mirroe imageof mine also [img]/ubbthreads/images/graemlins/smile.gif[/img]
    GReat choice in colour and spec [img]/ubbthreads/images/graemlins/smile.gif[/img]
    After owning Turbo Cars (Imprezas) there isnt much differnce in the Normaly Aperated egine betweent the Two in performance wise.
    Turbo owners stick to Shell Optimax because they say they see massive improvemements ober BP Super and other Super Unleaded Fuels.
    Please correct me here teck guys, but the 3.2 is tuned to use Super Unleaded as its 99 Ron.
    If you suddenly add Normal Unleaded Detination may occure (this normally happens with Import Turbo cars but not sure if it will happen on a 3.2 )
    Anyway difference in power id say approx 8 BHP
    But have never put normal Unleaded in the tank to try.
    Does anyone know if its possible to Re Set the ECU ?
    simonl's Avatar
    Jul 2005
    268
    I used to use optimax, everything else felt like i was driving around with the handbrake on.
    The only car i've ever really noticed any difference. Quite amazing considering it's NA not Turbo'd!
    Cupramax's Avatar
    Uber pimp meister
    UK
    455
    [ QUOTE ]
    [/ QUOTE ]
    You can reset the adaption values using VAGCOM, or just disconnect the battery for 10 minutes, the ECU will not allow detonation and will instantly back off the timing and hence you'll get less power if you go from super to standard 95.
    steeve's Avatar
    Nov 2004
    UK
    758
    Have tried both and not noticed any difference, no pinking either so I dont find it necessary to spend the extra.
    I did notice quite a difference on the STi I owned.
    Cupramax's Avatar
    Uber pimp meister
    UK
    455
    The ECU wont let it pink... read my post above.
    Dec 2004
    Manchester
    371
    Exactly, the ECU picks up the detonation before you can hear it and backs off the ignition, thus reducing the power output slightly.
    A rolling road is probably the only way to prove for definite. I always use super as there is a marked difference on the 2.0 turbo.
    DavidR's Avatar
    Scotland
    1,295
    I bet the difference is less than we think. Despite the 98ron suggestion for the 3.2 it seems unlikely that audi didn't engineer it to run merrily on cheaper petrol for the far corners of europe and I'd guess that the manufacturers power figures can be produced on 95.
    Anyone for a back to back RR?
    imported_migzy
    i've noticed a diference, unless it's just my imagination. But it seems that when i fill up with optimax the car seems slightly faster on acceleration.
    If i'm doing big mileage, i fill up with 95 though. no point spending big money if you're just cruising on the motorway
    simonl's Avatar
    Jul 2005
    268
    I'm with you on that one Migzy.
    previously LeeS3
    On the wirral...
    393
    I prefer to run BP ultimate in the 3.2. I really noticed a difference in low rev torque over optimax. I was suitable amazed (after religiously running Optimax in my last two motors). So now I run BP ultimate when available or default to optimax. Shells garages are in abundance in Chester, not so with BP.
    Recent Evo mag summed it up nicely, go with what ever your car feels best on, and throw in a few tanks of optimax for engine cleaning purposes.
    Feb 2004
    Clearfield, PA
    892
    usually there is a sticker saying which your car preferes...on the fuel cap lid...
    it usually says 95/98 ron saying it can run on both...just fine.. without any problems..
    you will notice a difference but its very small.. and personally the only reason why i use optimax is to keep the engine in good health as i usually give mine a good hammering..
