Chris NottVolks Autos
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Audi quattro
Thread: Audi a3 rear LEDs and coding
    Feb 2014
    17
    Just got it back after having the later led rears fitted to my car. My indicators flash red, I have a yellow light on permanently and the neon side light isn't on, they followed instructions but it does say will need coding after fitting
    Oh and no reverse, all bulbs are there they said
    The outer rings are not coming on, on sidelights.
    Btye 9 to Dec = 0 (mine says 00)
    Byte 10 to Dec = 0 (mine says 00)
    Byte 12 to Dec = 32
    Byte 19 Bit 2 Cold Diagnosis rear active (mine says be disabled)
    I am not sure what the 00 would do or the cold diagnostics rear active.
    Mar 2012
    52
    Did you put the adaptors on the correct side? Or will they only go one way? Did you connect the outer ring wire to the number plate feed?
    Feb 2014
    17
    It was fitted at garage and they said they followed the instructions, they said the lights need coding but I'm unsure how to go about it, surely I would see the outer ring lights
    Mar 2012
    52
    You need adaptors and the outer LED rings need to be tapped off the number plate lights.
    A3 Rear Light Face-Lift Install (summary of information)
    Oct 2012
    487
    Audi A3 8PA Sportback facelift LED rear light adapter cable | eBay
    are these what I need to go with the lights?
    Feb 2014
    17
    Hi mate took it for coding and they said they had no response, could the two adaptors be the wrong way round? Is there a left and right? As I just told the guy who fitted them for me he said they wer taped together but not labselled left or right, iv told him to start again and switch adaptors! Then il have to take it for coding again. I'm so close to giving up...
    Mar 2012
    52
    Did you check the guide i posted above? That's is a brilliant guide and couldn't be more clear.
    Feb 2014
    17
    Hi mate all sorted the adaptors wer the wrong way round, there are no faults or dash alerts do i still need them coding?
    May 2012
    perth scotland
    344
    Yes you will need them coded as your brake lights will be on permanently
    Audi a3 3.2 v6 sport back ,s-line, Dolphin Grey with factory tints, deg sat nav, bose speakers, 18 upgraded alloys, magnaflow exhaust, eibach pro kit springs
    Feb 2014
    17
    Yeh there are two red bulbs on Aswell as my outer neon light. This is not right is it, so the code I have seen on here should sort it all out yes?
    May 2013
    170
    That's right, if you use the code in the article link provided it'll sort it out.
    Feb 2014
    17
    All sorted thanks alit they look great
    Feb 2014
    17
    ImageUploadedByTapatalk1391700695.371587.jpg Thanks for all the advice and help they look great
    discostu49 likes this.
    Mindak's Avatar
    Nov 2013
    Wiltshire
    176
    Just out of interest where did you get your lights mate?
    A3 2.0 TDI S-Line
  1. Audi A3 Rear led lights anyone got any for sale?
    By djlazerblue in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th April 2012, 20:43
  2. Audi A3 Rear LED Lights Sport Back
    By S4 SWO in forum For Sale/Wanted - Audi Parts
    Last Post: 1st November 2011, 22:21
  3. Sportback rear LED's - coding should be 36 or 48
    By danb986 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th May 2011, 22:47
  4. Audi S4 Rear LED
    By Nez in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th August 2010, 04:07
