Sky InsuranceChris Nott
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Staz
Thread: 2008 s3 head lights problems
    Dec 2013
    Suffolk
    6
    Hi, I have a 2008 audi s3 3dr and am having a lot of trouble with the headlights, I seams when driving at night with the lights on low beam they just are not looking forward enough.
    I just cant find am adjuster anywhere?? i know they are auto adjust but its actually hard to drive at the minute. are the lights broken or fuse out maybe?
    Any ideas would be great thanks
    Ben
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    There are adjusters on the lights but from what I remeber they have to be put into an adjustment mode using VCDS before doing it otherwise it gets confused.
    8P2 S3
    26,762
    As Leon states, best option is to get someone with vcds & goto an mot bay & set the adjustment mode in module 55 using basic settings, then adjust manually via the 2 hex white plastic fixings on the top of the headlights.
    Suspension work usually throws this out & also possibly broken arms due to suspension or that area work done.
    http://wiki.ross-tech.com/wiki/index...ol_(Xenon_Plus)
    Dec 2013
    Suffolk
    6
    I have just got the car back form the stealers! ended up being a sensor on the back axle of the car. not too bad as got a new a3 tdi for the day and the s3 got a full wash and polish only cost £36.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Quote Originally Posted by Bensons3 View Post
    Happy days! Does that mean the car was always thinking there was some fat tw@ in the back?
    NHN likes this.
    8P2 S3
    Dec 2013
    Suffolk
    6
    yeah haha
    26,762
    £36 is very cheap if the rear sensor wasn't under warranty, as they're usually £114+
  1. Head light beam deflectors
    By jonny in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th August 2004, 20:49
  2. head light/bulb question... HELP!
    By NxJxHxCedge in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th May 2004, 12:13
  3. head light
    By godwine in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th May 2004, 21:56
  4. Head lights, rattle & a clocked car ??
    By Tiger6791 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2004, 12:40
  5. want to replace head lights on a4 1.8t sports
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2003, 22:15
