JMB RetrofitsSky Insurance
    Aldo's Avatar
    Jun 2006
    1,004
    P0102 Fault code
    Hiya,
    A3 stalled twice on me in a car park today, also sometimes jerks in to gears, probably because the revs are sometimes a bit uneven.
    Hooked up my Autel and found the following:
    Judging by a bit of searching, it seems to be a MAF issue.
    Anyway, is it likely I could be able to clean it up or should I just get a new one from ECP for £70?
    Where abouts in the engine is it?
    I have 3.26 engine.
    Aldo's Avatar
    Jun 2006
    1,004
    Mm been reading up more on this and maybe throttle body?
    Also heard a hissing from engine so hopefully just a loose pipe somewhere.
    Odd the traction light came on when it stalled!
    Aldo's Avatar
    Jun 2006
    1,004
    Well, maybe I'm chatting to myself lol
    Anyway cleaned up the MAF with IPA and clearest he code.
    So far so good and back to her usual self.
  1. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
