Results 1 to 7 of 7
    Jan 2014
    11
    Couple of questions/issues with my A3, from a newbie..
    Hi,
    having owned my first ever Audi for just over 3 weeks i have some questions to ask to the people with greater knowledge.
    I have spent many hours Google'ing and researching the forum here but some of my questions require a personal approach as i haven't been able to find correct answers. Quick background info... its a 3dr 2.0tdi SE 2004. 98k on the clock
    Issues with the car:
    • Clock.. This keeps on randomly resetting itself, Sometimes it will stay on and sometimes it resets every time i turn on the car. Did some research and some people have been suggesting its the battery, but then my trip computer would be reset too? and My radio frequencies? Or is the Trip computer on a different circuit? Could it be the battery? Car seems to start fine but sometimes struggles.. Not sure. Others have suggested that its a relay or a fuse somewhere. Don't want to buy a new battery to then find out it wasn't the issue.
    • Sometimes when the car is cold i can hear a rattling noise somewhere in the engine, as soon as i press any amount of accelerator this sound is gone but when released comes back again. Spoke to a seat owner and i was told it was the Idle pulley? Is this something i should be concerned/ worried about?
    • Engine light is on.. I knew this when buying the car from a PX dealer.. Hooked it up to one of those OBE? testers, got a code and google'd it. Apparently its the Throttle body. When i was getting my car valeted at Audi my friend hooked it up to the Audi diagnostics who confirmed it was the throttle body... Now everywhere i look on ebay they seem to be about £220 new and a bit cheaper used.. Not sure whether i should Buy one online and fit it myself or get a dealer to do it? I only ask because I've heard they need adjusting Via VAG-COM after fitting? To which i have no access to.
    • Should my cluster look like the picture? 20140112_191648_zpsqezwag7m.jpg I only ask because my car doesn't have the middle screen showing certain stats but there is space for the screen? Cant tell MPG etc? Or was this part of only selected models? Shouldn't my "special edition" have it.?
    • Any other general things i should know about?
      Sorry for the long questions but this is my first personally owned car and i invested a lot of money into buying this so i would like to get it to a fully working condition and then look into other options. Any help is greatly appreciated.
    Thanks for reading, if you got this far :D
    Jan 2014
    21
    The middle screen is the driver information system. If it just has the dummy signals then you won't have it. Some will have the facility for it to be upgraded via VAGCOM otherwise it's an expensive retrofit.
    I don't know a lot about car engineering but I've heard of idler pulley bearings getting a bit raggedy over time and that's not too expensive a change. Stick it with a good local garage (I really wouldn't bother with an Audi main dealer - others might disagree) and get them to do the work on that and the throttle body themselves. Whether you buy the part new or second hand is again a matter of personal preference.
    As for the clock issue, you could try only starting the engine at 00.00? Probably a fuse or alternator, doubt it's the battery.
    Jan 2014
    11
    Well where that screen should be i have seen the boot open light but nothing else (so i guess my car doesn't have it).. Was just a bit disappointed when i realized it doesn't show mpg.
    As for the throttle body I've hear that there is a batch number L that has the problem with 04 throttle bodies breaking.. and there is another 2 batches that are the "new" version that don't suffer from the same fault G and M models if i remember correctly?
    Haven't actually been able to check what part number my throttle body has as I've been busy with work and life :D
    So how shoul i go about finding whats broken that would cause the clock to restart?
    Jan 2014
    11
    Bumps
    Jan 2014
    11
    Another question... If anyone would like to help.
    I dont like how the sub rattles in the crappy enclosure in the boot.
    Im planning on making a custom enclosure and swapping it for the ice cream tub one.
    My only question is Will it work if i use a sub thats rated at 180w with the existing wiring/ amp etc. I realise it wount be fully used but it was free and im looking to get rid of the rattling without spending much money.
    Jan 2014
    11
    Bump
    Jan 2014
    11
    Anyone?
  1. iPad issue with photo sync from iPhoto
    By warren_S5 in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 30th August 2011, 11:35
  2. Couple of issues with my S3
    By cooni in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th February 2008, 22:05
  3. Hello from newbie and a couple of questions
    By ARSEY4 in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 15th August 2007, 20:17
  4. couple of questions from a newbe
    By S3 AD in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2006, 21:58
  5. A couple of question for you guys with new S-Lines
    By Roswell in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th September 2005, 21:15
