Sky InsuranceEM Tuning
Results 1 to 17 of 17
Like Tree5Likes
  • 1 Post By Dave-S3
  • 1 Post By Alexthekidd54
  • 1 Post By JamesS4cab
  • 1 Post By Mamba
Thread: S3 Alloy wheel spec help
    Jan 2014
    7
    I'm sure this has been asked many times, but after trawling the forums can't seem to get a straight answer.
    I have an 07 S3 with 18" 8J ET35 225/40/18's. Standard suspension.
    They have never been that great. After fitting, the car lurches around corners, speed humps and pot holes are not kind to the tyres on the inside of the arches.
    I'm looking at getting 19" 8J ET45 with 225/35/19 tyres.
    Anyone ever fitted these wheels and tyres with this spec and standard sus, i.e. any rubbing?
    I'll chuck some £££ at the sus at some point, but want to get this sorted first.
    Any advice appreciated.
    Jun 2012
    Chester
    566
    Visit Dave-S3's Instagram Channel
    19"s are going to ride harsher, fact.
    S3Alex likes this.
    2009 S3 S-Tronic, Ice Silver, Black Edition - 280 BHP & 296 Ftlb
    Feb 2013
    Grimsby
    1,085
    ^ what he said.
    go down to 17's if you want a bit more comfort.
    05, A3 8P 2.0TFSI Quattro
    Alexthekidd54's Avatar
    Aug 2013
    25
    Either upgrade your suspension or upgrade your spine I know which is cheaper
    Dave-S3 likes this.
    Audi A3 2.0TDi S-Tronic 140BHP Black Edition 2011
    Aug 2006
    NI
    785
    Et35 not rub like crazy?
    Standard is et54!!
    back to boost, oh how I missed thee....
    JamesS4cab's Avatar
    Mar 2008
    1,120
    Don't listen to them. Its all about what it looks like. I had 5 different sets of 19's on my S3 and it was horribly uncomfortable on H&R springs. But it looked the ********.
    Comfort is for old people.
    Hence why i now have a BMW with EDC and "comfort" suspension..........
    Mamba likes this.
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    Jan 2014
    7
    Quote Originally Posted by JJ.Foulds View Post
    ^ what he said.
    Not too bothered about comfort, just don't want the tyres to catch on the arches. Will prob upgrade the sus later...
    M
    Jan 2014
    7
    Quote Originally Posted by pablo View Post
    Standard is et54!!
    No mate - only rubs going over uneven road at high speeds or speed bumps, otherwise they're OK unless you've got a bunch of fatties in the back! (running 225/40/18s)
    I read on the Audi specs site, that the standard wheel ET is 56 on the 57 plate S3.... Thing is I have been looking for aftermarket wheels of that sort of spec and I've not been able to find anything above ET45 for less than £1200!
    Jan 2014
    7
    Quote Originally Posted by JamesS4cab View Post
    Lol - so 'old fella' (sorry, had to be done) comfort / suspension aside, and as an experienced S3 owner, can you advise me as to whether I can get away with 19" 8J ET45 and 225/35/19 tyres, without rubbing?
    M
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,281
    Quote Originally Posted by Mamba View Post
    With respect Mamba, are you sure you want to do this?
    Tyre size, the 225/35/19 has a rolling circ of 1955mm where the 225/40/18 is 1945, so no problem there.
    However, the outside edge of the 19-inch ET45 wheel/tyre will be 10mm INWARD from the current ET35 wheel/tyre, and that may not be the look you are after.
    Here's a diagram I prepared for the RS3 guys thinking of doing similar (this is the same 8J rim but with and ET50 and the distance from the mounting face to the outside of the wheel rim shown 68mm (ok, should be 68.5)):
    Do your own maths and make sure, and feel free to ask...
    PS: a 225/35/19 on an 8J ET50 rim is standard for the rear of an Audi RS3
    Jan 2014
    7
    Cheers 45bvtc, thats really helpful and useful enough to make an informed decision. I've gleaned from what you are saying that it'll be cool, and they won't rub, but it might not 'look' as desired.
    Ultimately, I don't want the tyres to catch on the underside of the arches using 19" 8.0J ET45's. The current ET35's stick out a bit and rub every now and then, that and I've never warmed to the design or their handling, so you can appreciate where the 'higher offset / larger dia / skinnier tyre' line of thought has come from...
    45bvtc likes this.
    JamesS4cab's Avatar
    Mar 2008
    1,120
    Unless you are taking 4 large mates for their weekly weigh in at Weight Watchers, you should have no problems.
    I have run 8, 8.5 and 9J width inc BE rotors from an a4 and I had a small amount of rubbing on the front with 235 so dropped to a 225 profiles but then I was dropped 25mm. Removing the usual arch screws helped front and rear.
    With regards to rolling diameter, I really wouldn't get hung up.
    Mamba likes this.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,273
    The rolling diameter... Your speedo will be 0.5mph out over each 30mph you go up... I.e 30 would be actually 29.5mph, 60 would be 59mph etc.... Not exactly an issue... Et45, 19" 225 tyres on 8j.. Remove couple of arch screws... Perfect!
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
    Jan 2014
    7
    Quote Originally Posted by S3_Jacko View Post
    Thanks Jacko! :-)
    Have read about arch screw removal but not 100% sure what it means? Assume under the wheel arch there are plastic 'infills' that are held in place by said screws, removal of which removes the plasctic, ergo increasing the 'space' under the arch?
    M
    JamesS4cab's Avatar
    Mar 2008
    1,120
    Thats about the sum of it!
    If you feel under the arches there is one at the rear, and when i was running 9J at the front, there was one on the front. Doesn't have any impact on holding the trim on!
    When i first ran 9J with 235 on the rear, i did take a Dremmel to a small are on the rear bumper as well........
    Jan 2014
    7
    Talking
    Had a look under the arches, there are a number of allen key bolt fixing points for the plactic under the arch... Assume I don't have to remove ALL of these?
    You refer to 'one' on the front and rear.... Any guidance as to which one (screw) you're alluding to?
    M
    br20vt's Avatar
    Sep 2010
    Middlesbrough
    141
    I ran 19 x 8.5 ET45 Helios on mine with 25mm H&R springs with no rubbing issues what so ever. Before that i had 18 x 8.5 ET35 squared sc1's which gave a bit of poke and rubbed over average sized bumps.
    Ibis S3 8P3 - Airlift V2 / S63 AMG wheels / RS3 Grill / Recaros
    Previous: Polo 6n2 20vt / S3 8L GT28
    Instagram: @bradraistrick
    http://www.audi-sport.net/vb/a3-s3-s...s3-thread.html
  1. Alloy wheel expert help needed
    By MTRL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th January 2012, 16:13
  2. DIY alloy wheel refurb help
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2007, 19:03
  3. Alloy Wheels for S3, Please help !!
    By BigSimon in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2005, 19:26
  4. Another 18" Alloy Wheel Discussion - help
    By IanL-S3 in forum Handling
    Last Post: 19th February 2005, 01:01
  5. FAO EVERYONE - My Alloy Wheels - HELP PLEASE!
    By richy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2005, 00:59
