Monster MotorsportBadger5
    Jan 2014
    a3 tdi 170 flat spot when setting off
    hi all, ive had my a3 for 2 years and its got 130k on the clock now. about 3000 miles ago the turbo went so sent it in and had a replacement fitted(brand new). about 1000 miles ago it seems to have developed a flat spot when attempting to set off quickly.
    when i set off it is very flat then all of a sudden it puffs a big cloud of black smoke (i had the dpf removed and deleted) then boosts as it should do?
    would a remap cure this?
    thanks
    paul
    Jan 2014
    anyone have any ideas?
    May 2014
    Hello. Did you ever fix this problem? My car is exactly the same with no fault codes. The garage I brought it from couldnt fix and and are refusing to do any more. Thank you
  1. crunching noise when setting off.
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th March 2011, 22:23
  2. Replies: 2
    Last Post: 25th February 2011, 21:49
  3. Squealing noise from Clutch when setting off in 1st
    By evilbane in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd January 2011, 17:23
  4. 2.5 TDi Quattro Flat spots
    By chris444cat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th January 2010, 10:47
  5. S3, flat spot when pulling away!
    By DPM in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2006, 10:05
