EM TuningVolks Autos
Results 1 to 17 of 17
    CurtisS3's Avatar
    Jul 2011
    Merseyside
    12
    Still Rough Idle
    Hi all,
    my 2008 s3 Sportback recently starting revving on its self. when on idle and when coming to a stop with the clutch depressed. the revs sometimes go upto 2000rpm and then when it comes down it make like a miss fire sound..
    since i have read about this problem on here before everyone seems to say replace the PCV. I've done this along with the gasket and still no change in the erratic idle.
    has anyone got any more suggestions???
    ive not had it scanned since it started maybe that would help i don't know as there are no engine management lights on etc.
    any ideas welcome cheers curtis
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Vacuum leak.
    CurtisS3's Avatar
    Jul 2011
    Merseyside
    12
    were am i looking for this, the two hoses that clip onto PCV ???
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Yes, plus ALL other vac hoses / pipes... Fiddley time consuming job.
    Also check oil filler cap and dip stick seals.
    CurtisS3's Avatar
    Jul 2011
    Merseyside
    12
    ok. so now the engine management light has appeared, hopefully get it plugged in tomorrow. this may sound dumb but where are the other vac hoses/pipes and whats the best way to check for the leaks ??
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Visit s3joe's Instagram Channel
    Quote Originally Posted by curtistimmins View Post
    I have got a code reader if your anywhere near Liverpool
    CurtisS3's Avatar
    Jul 2011
    Merseyside
    12
    were are you mate ?
    CurtisS3's Avatar
    Jul 2011
    Merseyside
    12
    im in knowsley
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    im in knowsley
    I am in Crosby mate I'll pm you my number
    Jan 2014
    25
    its nice to see people sharing their toys with people
    Dec 2012
    243
    Cam follower maybe??
    Have a look at this:
    2.0T cam follower replacement and look how bad this is!!
    2010 Condor Grey S3 Sportback S-Tronic. 354bhp 414ft/lb.
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    I have a good used one here if that's gone
    CurtisS3's Avatar
    Jul 2011
    Merseyside
    12
    if i unplug the MAF it flattens out back to normal. would people recommend to replace it ?????
    Dec 2012
    243
    Yes
    CurtisS3's Avatar
    Jul 2011
    Merseyside
    12
    any particular one, Bosch or cheap one of ebay ??
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    proper one from reputable supplier...
    CurtisS3's Avatar
    Jul 2011
    Merseyside
    12
    bought a maf from TPS fitted, went on a run out still the same, revving unto 2000rpm then stuttering on way back down. still if i unplug the mac it flattens out. really annoyed with thud now, engine management light still on to. could do with a VCDS plug in, any one know of one in liverpool, warrington st helens area ???
  1. Rough Idle
    By 1mran in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2007, 22:37
  2. Rough Idle
    By melman in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2007, 19:29
  3. Rough Idle now to tranny prob A4 2.8
    By ad3crk in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th October 2006, 18:35
  4. Rough Idle
    Last Post: 8th October 2006, 09:52
  5. Rough idle after cambelt change
    By in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th June 2005, 18:19
Tags for this Thread
