Volks AutosAH Fabrications
    Nov 2013
    26
    A3 Boost Problem
    A3 Quattro 170 hp BMN engine, egr,dpf deleted ,remapped.Car went really well for 2 months after remap,egr,dpf delete.Loads more torque and much better fuel economy. Then one day it started to miss over 1/2 throttle at 2000 - 2400rpm .It feels like the ecu is cutting back on fuel every half second.It`s power on off on off on off. Once it gets past 2400 it doesn`t miss but feels slower than it was.If I accelerate slowly through 2000-2400 it doesn`t miss.Changed the fuel filter (which was clean), changed N75,disconnected MAF, no change.Turbo actuator G581 holds vacuum all day and turbo vanes very free. No MIL ,vcds shows all clean.No limp mode.Oil level changes. Torsion value 0* .Good quality diesel with injector cleaner .The miss has been there every day.Anyone any ideas? Will pay someone with vcds to find the problem. Manchester,Bolton area.
    Aug 2013
    new battery
    Nov 2013
    26
    It`s not the battery.This is a fuelling problem.But thanks for the reply.
  1. boost problems
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2005, 17:16
  2. MOVED: S3 Boost Problem
    By bampy in forum The Welcome Section
    Last Post: 30th May 2004, 23:04
  3. Boost Problems!!!! New Owner So Quite Worried!!!
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2004, 12:50
  4. boost problems - following remap
    By tim99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 12:59
  5. S3 Boost problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2004, 23:13
