AH FabricationsEM Tuning
Results 1 to 8 of 8
    Jan 2014
    7
    Audi A3 Seats Upgrade heating issues
    Swapped my cloth heated seats out for a lovely set of Leather heated Nappa s3 seats.... They heat up lovely but will not allow my car to control heat or tun down... Please help with advice... Is it a VCDS JOB... I do not know if these came from climate control car or just heated seat car.. Does this make a difference ??
    Any help or advice please
    Using Tapatalk
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    You will prob need to update the climate control module aswell as it also has the heated seats controls on it too and then adjusted via vcds... Dont quote me on it, but i'm pretty sure that would be the case? Anyone??
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
    Jan 2014
    7
    Thank you for responding mate....My car has heated seat controls in it already but just doesn't have climate control.... Will I be able to get them to sync together with VCDS mate
    Using Tapatalk
    1,877
    Heated seat don't work like the climate control system, there are no sensors to monitor how hot your @rse is, its a manual system.
    Jan 2014
    7
    Avoovi
    Bo.
    Using Tapatalk
    s3ollie's Avatar
    Jan 2007
    749
    Quote Originally Posted by B5NUT View Post
    there are small thermostats in the seat so they don't get too hot. If you use vcds it can tell you requested vs actual heating for the seats
    8P S3
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    Quote Originally Posted by Siena547 View Post
    So I take it your car never had heated seats then and you have retrofitted both the control unit and the heated seats?
    Jan 2014
    7
    Yes it already had heated seats but not climate control.... It appears the wiring of the plug is diff on the climate controlled leather seats as opposed to just manual controlled heated seats..!!!
    They plug
    In the same and switch on but can't
    Be switched off !!
    Using Tapatalk
  1. Audi A4 b6 front heated seat elements
    By steveboyo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th January 2011, 18:54
  2. Audi Sport Seat upgrade B5 Quattro
    By Jonnysideways in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd January 2011, 17:47
  3. audi a4 cab b6 heated seats
    By 1kevin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd September 2010, 20:35
