Monster MotorsportEM Tuning
Results 1 to 11 of 11
    Nov 2013
    Sheffield
    41
    clicking/cracking noise PLEASE HELP
    My 55 bkd quattro has a clicking noise on either full acceleration from set off or under harsh braking it also clicks on full lock when reversing or turning slowly but not all the time
    it always clicks wen accelerating from 1st or braking hard it dose not click wen driving normally around roundabouts or any other corner for that matter just when turning slowly
    PLEASE HELP REALLY ANOYING
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    stone wedged in a tyre type clicking???
    2009 A3 SB 2.0T DSG S line
    Nov 2013
    Sheffield
    41
    Wish it was pal
    Nov 2013
    Sheffield
    41
    Really hard to explain like clicking/cracking sound checked seems to come from the drivers side checked drive shaft n cv joints n they all look ok not splits
    1,872
    You can check a CV boot by looking but You cannot check a CV joint by looking at it, you are going to have to strip it down. From what you have said in your first post it does sound like a failing CV joint.
    Nov 2013
    Sheffield
    41
    So buy a new drive shaft ?
    Jan 2012
    SW London
    751
    Check to see if any bolts are missing on the driveshaft and/or if the link between the bolts are broken/loose
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Nov 2013
    Sheffield
    41
    Checked it all to day looks mint in regards to bolts n the links il just change the whole driveshaft n go from there
    Any recommendations for we're to get a genuine a2 quattro drive shaft?
    Had a look J R driveshafts but not to sure about them ?
    1,872
    You don't need to buy a drive shaft CV joints can be purchased separately, but first garage to check it over before spending the cash.
    May 2013
    Stafford
    53
    Follow john71482 On Twitter Visit john71482's Youtube Channel
    I had the same problem and after months of trying to find out what it was I found it and it was a bolt on the subframe! All sorted now!
    Jan 2012
    SW London
    751
    Quote Originally Posted by B5NUT View Post
    What he said. Get the driveshaft balanced while ur at it
    VCDS User
  1. s3 strainge clicking noise help !!!!!!!!
    By stus32007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th February 2008, 11:26
  2. Clicking noise in 1st gear
    By bmerrilees in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th November 2004, 17:13
  3. clicking noise as front wheel turns on A4...
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th August 2004, 21:59
  4. clicking noise from air vent???
    By xdam in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2004, 00:53
  5. clicking noise on tickover
    By pwnorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2003, 18:22
