Chris NottBadger5
    Jul 2013
    Manchester
    112
    Second hand instrument cluster and programming?
    Hi all,
    My thread about the FAULT: Audi A3 sportback - Problem (VIDEO)
    So my instrument cluster went to BBA and they said the instrument cluster was fine.
    I took my car to an Audi Specialist today and they said they have seen the exact problem before and it was the cluster.
    They also said because the problem is intermittent and sometimes works. When BBA tested it the cluster it was probably working. Which means I paid BBA £70 for nothing
    Anyway im wondering whats the cheapest way to replace the Instrument Cluster?
    Instrument Cluster Part Number (from VCDS) - 8P0 920 982 CX
    Thanks in advance
    Jul 2013
    Manchester
    112
    Cannot find a used one of these anywhere on google, any suggestions?
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    448
    Try searching without the X at the end mate.
    If memory serves correct the X stands for exchange.
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
    Jul 2013
    Manchester
    112
    Will do, thanks ryan
    May 2012
    RETFORD, NOTTS
    1,753
    Coding like for like on your car 'should' be relatively straightforward. Check.the clocks you buy are working. If possible buy them with a working key from the car
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Instrument cluster and ECU fail - did I wreck them??
    By Rupert25 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th December 2013, 07:32
  2. A3 and A2 instrument cluster
    By M88JCP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th April 2010, 22:39
  3. No backlighting for Instrument cluster and Dash....
    By muz_amin in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th December 2009, 20:28
  4. Instrument cluster and horn
    By sniperlover in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th March 2009, 15:28
  5. Sony Head units and the instrument cluster display
    By Ram in forum In-Car Entertainment
    Last Post: 14th April 2003, 23:30
