JMB RetrofitsSky Insurance
    Jan 2013
    23
    Is the a Tow Bar Kit out which doesn't require a bumper cut Audi A3 TDI 2005 Quattro
    Hi all,
    I need to get a tow bar for my Audi A3 2005 Quattro and wondered if there was a kit where I don't have to cut the bumper. I'm not over keen on cutting the panel work just incase I decide to see up later on.
    Any help or advice is appreciated.
    Cheers Dave
    Jul 2013
    311
    yeah i would imagine a good detachable swan neck tow bar should do the trick but please check first as they normally do but the cost is alot more on this style compared to a normal one
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    I had a Westfalia detachable tow bar on my 05 A3 along with a replacement valance that had a hatch that could be removed to fit the tow bar, and refitted to make it completely invisible when the tow bar was removed. It wasn't cheap though, roughly £500 fitted including getting the valance sprayed the same colour as the car. Would be cheaper if you could get your hands on the kit yourself though I'd imagine.
  1. Bumper / tow bar / cut out
    By Juddies in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2013, 19:24
  2. Removable tow bar S line kit
    By Shane-Ireland in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th September 2010, 19:00
  3. A real car: The Audi A3 TDI clubsport quattro
    By gameboy2901 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th April 2009, 09:40
  4. GMBH Kit out the factory?
    By Colin_S in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd May 2005, 13:05
  5. Thank you to the man with the tow bar
    By PaulBelsham in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2003, 17:00
