EM TuningVolks Autos
Results 1 to 12 of 12
Like Tree10Likes
  • 5 Post By mjr901
  • 1 Post By carpetbagger
  • 1 Post By mjr901
  • 1 Post By s3_trev
  • 1 Post By Alex_007
  • 1 Post By fangio
Thread: DRL question
    Nov 2013
    294
    DRL question
    Hi
    Does anybody know if DRL's can be turned off somehow?
    55 plate Audi A3 2.0 tdi 140 sportback
    07 plate BMW M5 estate with lots of extra power.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    ummmmm the off setting
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Nov 2013
    294
    Quote Originally Posted by mjr901 View Post
    Ok cheers, it was for future reference as I'm thinking about getting a new motor .
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    Quote Originally Posted by Alex_007 View Post
    If you have autolights variation of switch, 'auto' mode will leave the DRL's on, but the 'O' will switch everything off no matter which switch you have.
    There's also Scandinavian mode to play with using VCDS. When DRL's are on the rears aren't usually on too. However changing this setting allows DRL's and rears to be on.
    Nov 2013
    294
    Ah I see , ok lovely thanks for that , that's good to know .
    Nov 2013
    49
    Hi on my a6 the drls only work on the 0 position but these can be turned of by using the mmi system hope this helps
    Alex_007 likes this.
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    Quote Originally Posted by carpetbagger View Post
    I'm pretty sure the 8P chassis still fell into the non compulsory constant DRL as its a good few years old now!
    So either cars with more technology in them or newer would generally have this.
    Nov 2013
    294
    Thanks , so I assume they can be turned off across the whole audi range , nice .
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    629
    I know I can enable my DRLs to be ON when the light switch is in the OFF position, using vcds. Not sure if its possible to do the opposite though. Probably is.
    Audi S3 8P3 / REVO Stage 1 / REVO Ceramic Intake / NGK Iridium Spark Plugs / LOBA HPFP / Philips Diamond Vision 5000k Fog Light Bulbs /
    KW V3 Coilovers / Team HEKO Wind Deflectors / Bridgestone Potenza S001 92Y Tyres / Complete LED Bulb Conversion (int' + ext') / Ashtray Delete /
    TTS Engine Cover / Alpine 928r Multimedia Station (8in screen) with integrated Bluetooth, Sat Nav etc / Ross-Tech VCDS Owner.
    Nov 2013
    294
    Quote Originally Posted by s3_trev View Post
    Thanks , as long as there is a way of turning them off if I wanted to then happy days .
    s3_trev likes this.
    Mar 2011
    Cleveland
    996
    Good lad!
    Nov 2013
    294
    Quote Originally Posted by fangio View Post
    Good lad!
    Thanks ,
    I like the look of the headlights just not a fan of then being switched on in the day time.
  1. Drl question
    By Ash92 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th October 2013, 18:09
  2. another DRL question...
    By Ash187 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th May 2010, 16:44
  3. Facelift owners with DRL's, headlight question
    By Sem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2009, 11:22
  4. DRL Question
    By mac1403 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th October 2008, 21:56
  5. DRL question
    By stewarta13wsb in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2007, 21:49
