If you have autolights variation of switch, 'auto' mode will leave the DRL's on, but the 'O' will switch everything off no matter which switch you have.
There's also Scandinavian mode to play with using VCDS. When DRL's are on the rears aren't usually on too. However changing this setting allows DRL's and rears to be on.
I know I can enable my DRLs to be ON when the light switch is in the OFF position, using vcds. Not sure if its possible to do the opposite though. Probably is.
