AH FabricationsJMB Retrofits
Results 1 to 17 of 17
    Dec 2013
    26
    2006 bad - very bad headlights
    Hi, only had a couple of drives in the car in the dark but dear are the lights bad.
    It looks like there are different bulbs as the light is quite white but the lighting of the road is really bad. Are the lights really that bad or is it potentially down to the lad before fitting crappy bulbs?
    I was thinking of asking t8ups for some bulbs.
    These are the lights in question
    Feb 2011
    Plymouth
    1,141
    could either be cheap ebay tat or phillips diamond visions
    Audi A3 Sport 1.6 2006
    Aug 2010
    Chelmsford, Essex, United Kingdom
    72
    Quote Originally Posted by dano200 View Post
    The high beam bulb looks like its not sitting correctly for starters from the picture but I find the same thing with my light be it OEM bulbs or aftermarket "white" bulbs which is why im looking to save up and get a new car with xenon atleast :D
    Mindak's Avatar
    Nov 2013
    Wiltshire
    244
    Quote Originally Posted by smurfworth View Post
    I think my diamond visions are quite good compared to other bulbs I've had!
    I'd say they need aligning personally, drive up to a wall /garage door and see if the beam pattern is correct!
    A3 2.0 TDI S-Line
    Aug 2013
    Surrey
    135
    Those bulbs look quite cheap and nasty! Fit some decent rated bulbs eg Philips or osrams and see how you go
    Dec 2013
    26
    Thanks for the reply's, I have taken the main beam one out (t8ups was asking about the Wattage), and refitted. It does seem to sit better. They are 55w. Will see now what t8ups can offer bulb wise. Maybe it sitting better will make it work better.
    I don't know why people fit cheap rubbish bulbs.
    Schizophonic's Avatar
    Jul 2013
    Northampton
    321
    What about polishing your headlights?
    Oct 2012
    492
    The lights are crap on my a3 I have fitted bulbs from t8ups they are a bit whiter but its the beam from the headlight is very poor my old passat was the same you would think with it being twin headlights they would be good but its not the case I fitted hid in my passat in the end but the a3's dont like aftermarket hid and the oem are expensive I am wondering if higher wattage bulbs will be ok in them?
    Dec 2013
    26
    oh dear are they really just that bad?
    Oct 2012
    492
    They are mate yes I think you can fit after market hid if you run seperate earth to them instead of useing the original shared earth
    Feb 2011
    Plymouth
    1,141
    My lights are awesome now: Well Done HID - Review
    Oct 2012
    492
    I sent them an email weeks ago no reply mate
    Feb 2011
    Plymouth
    1,141
    They only reply on whatsapp. You'll get an almost instant reply there.
    Boon's Avatar
    Sep 2012
    South East Kent
    417
    Is it only me that think the standard H7 reflectors are ok?!!!
    I use Halfrauds Extreme Brilliance and never felt that I need more light...
    And I even mainly drive my 16yr old van (with the same bulbs but in H4) and still don't think they are too bad!!
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Top Gear!
    Sep 2010
    N. Ireland
    275
    I do a lot of driving, I prefer driving at night as well
    I have a set of these in mine and they are on par with xenons IMO, I rarely use my main beam as i see no need for it with them, they're not cheap but then can you put a price on safety?
    Philips 12972-XVS2 H7 X-Treme Vision 100% Kit (2 Bulbs): Amazon.co.uk: Car & Motorbike
    They are inserted correctly and levelled perfectly yet people oncoming at night think i have my main beam on and flash me, similar to what happens in a bi-xenon equipped cars.
    I was of similar opinion and i think unless i buy an older car my next will have xenons
    Mar 2012
    369
    I have OEM bulbs in the same OEM housings as you and they are fine, if not wonderful. Of course, having had OEM HIDs in my two previous cars, they aren't as good, but they aren't bad.
    Dec 2013
    26
    Quote Originally Posted by JohnE View Post
    That's interesting, looks like it's the rubbish bulbs then.
  1. HELP!! very BAD fuel consumption Update!
    By adzy in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2011, 11:16
  2. VERY BAD FUEL CONSUMPTION!....HELP!!!!
    Last Post: 5th January 2011, 09:48
  3. Air con...very bad noise
    By cerbera4_0 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2010, 21:42
  4. LOL, Warning very bad language.
    By S3-Oski in forum You Tube Links
    Last Post: 15th January 2010, 00:04
  5. HELP - Car in very bad way....
    By tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2009, 18:32
