AH FabricationsChris Nott
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By hollow
Thread: Turbo gone :( - Could do with some advice
    Feb 2013
    129
    Hey guys,
    So a great start to the new year... I've nearly gone blind and had to have retinal detachment surgery and now my turbo has gone on my car.
    A family member took it into audi for me and asked them to give it a once over and to do the following:
    • New turbo
    • the starting is lethargic in the morning when its cold, advise
    • diagnose the resonance in the back of the car between 60-80 (most likely down to the propshaft donut?)
    They've got back to me and said that the turbo needs replacing (fair enough) and the battery because thats causing the poor starting. But the resonance in the back of the car is down to the turbo (I call bull****).
    Oh and they want £1650 for a new turbo and new battery (not sure if this is including vat, need to double check).
    My question to you guys is, would it be more economical to get the turbo refurbed or to get the turbo from elsewhere, if so any suggestions?
    It's probably worth mentioning thats its been remapped and I don't want a cheap **** turbo!
    Audi A3 2007 2.0TDI 170 Quattro S-Line Sportback, fully kitted
    May 2009
    south yorkshire
    628
    you could buy a brand new turbo from tps for a lot less than that and either fit it yourself or get an indy to fit it , please dont buy a cheap aftermarket one from ebay it will be knackered in a few months , also dont get a recon same applies . i would rather buy a good secondhand unit rather than a recon . sounds like the battery could have cell damage and is loosing cranking power .
    resonance no idea without hearing it .could be a number of things
    theres a genuine secondhand unit for the 170 on ebay for £200 if you dont want to be spending loads .
    mozza1202 likes this.
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,406
    Follow Brodster On Twitter Add Brodster on Facebook
    Afew guys on here do turbos...........xman750 and Dan@Beachuggy turbos both do great deals on replacements or hybrid or whatever route you wanna go down. Give them a PM and see what their prices are like. A lot cheaper than the dealers.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    Jan 2012
    SW London
    794
    Alongside changing the turbo you should consider doing an oil service and maybe replacing oil feed lines. Thats what i was advised to do when i bought mine (which i still havent changed). I thought my turbo was going, turned out it was two massive boost leaks, so i still have mine sitting around at home.
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Feb 2013
    129
    Cheers guys, rang around garages and one indy suggested going hybrid so phoned turbo dynamics and they recommended:
    MD550 Stage 2 Hybrid Turbo for Golf/Passat 2.0TDI 170bhp engines MD550 Stage 2 Hybrid Turbo for VW Golf 2.0TDI 170bhp engines [MD550] - £1,030.00 : Turbo Dynamics, Turbochargers & Performance Products
    Anyone had one of these before / heard anything about them?
    May 2009
    south yorkshire
    628
    nephew had one for his 170 a4 which is very similar . cost him £1300 inc vat from them .then a remap at rs in leeds £ 500 . turbo struggled to get 235bhp . masses of torque though, too much in fact .
    hell of a lot of coin for 30 bhp . swapped it not long after for a golf edition 30 . since then the hybrid turbo is dead hotside melted away .
    turbo is or was around 8 months old .
    Feb 2013
    129
    Quote Originally Posted by hollow View Post
    That's what I heard that they run hot, something to do with the EGTs?
    Thing is, I wouldn't want Rick the tuner to push the car, I would want a smother torque line than what I have now (I have about 190 as it stands) so maybe push it to 200-210. I'd want reliability over performance.
    So probably not worth it then, I just have this upgrade bug - e.g. if something breaks, replace it with something thats better!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    dont put the lad off recon turbos
    iv had at least over 50 done for diffrent cars
    and they can and do last very good miles
    buying secondhand is a gamble
    May 2009
    south yorkshire
    628
    might as well buy a gt 2260 then and do the injector swap ,go to around 290 bhp
    May 2009
    south yorkshire
    628
    the recon route is a gamble just like secondhand ,but if you read the warranty for a recon turbo it always states to replace the oil feed pipe to the turbo and it has to be fitted to a competent trained mechanic . ive stood in the garage before whilst we have had these arguments with turbo companies on the phone when they try to wriggle out of warranty claims on recon turbos.
    bez101's Avatar
    Jul 2008
    8,530
    yeah i agree all turbos should be refitted with a feed pipe and oil and filter
    kinda daft not to and i wouldnt replace under warranty any that hadnt been fitted with new feed pipe.
    but if fitted correct and a fault shows then they will sort them on a claim.
    May 2009
    south yorkshire
    628
    must have better luck than we do then ,except for the obvious self destructing ones .
    davc's Avatar
    Foursprung Duck Technik
    Jan 2013
    Caledonia
    217
    Quote Originally Posted by Napbree View Post
    Turbo Dynamics are a reputable name. I ran an MD376 on a pd150 for over 30k miles with no issues whatsoever, but my car was custom mapped and EGT's weren't excessive. I would choose one of their units over a recon'd one every time.
    At the end of the day, turbo reliability is partly down to how the car is mapped.
    MY'09 S3 Sportback |Gloss Black Mirrors |Buckets |Black Optiks |Open Sky |Light & Rain Sensor Pack |CH/LH Lights |RNS-E & No Highs No Lows it must be Bose |
    Oct 2012
    95
    Regarding the resonance through the back of the car, I get this at a specific rev range, usually about 2.5k revs driving steady, most noticeable in 5th or 6th gear. Can be quite frustrating and I generally just accelerate a touch until it goes. No idea what causes it though, maybe a slight exhaust issue??
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,220
    My car is same year/model and it's the 170 like yours. I got it remapped and dpf removed almost as soon as I bought it as I hated the "lag" the car had.
    I bought the car at around 68k, 11 months ago and it's now at 97k. So in a year it's basically done 30k which is quite a lot for the car and it doesn't help that I haven't been as easy as I could of been on it. The main things I've had done to it are:
    - Rebuilt gearbox
    - New turbo
    - New set of pads
    - New clutch
    - New Dual mass flywheel
    - Also needs a new propshaft/new bushes to stop resonance at 65+.
    So basically its a new car, however, in your case I'd say those parts are likely to go relatively soon anyway (but who actually knows, they could last till 200k+), but having the map put on it will definately increase the likelihood of the parts going sooner
    Best thing I did was get warrantydrect because they've paid out, but if you do decide to go with them, pay a little bit more and get a higher labour rate (which I didn't).
    you had a new turbo done recently to it, and its gone again?! I would see if there was warranty on that new turbo if its been under a year
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
  1. new to the site could do with some help
    By kirky1966 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2014, 20:25
  2. Could do with some advice
    By tom2 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd July 2013, 20:04
  3. I've looked on the forum and can't decide yet. Please help with some advice.
    By Simon170TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2013, 17:40
  4. Could i get some advice?
    By Gops in forum General Chat
    Last Post: 6th March 2010, 18:07
  5. A3 TQS Head tweaks and upgrades? Could do with some advice
    By Fandango80 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2007, 18:37
