Badger5Volks Autos
Results 1 to 13 of 13
    Jan 2014
    23
    Aparently i have a sealed gearbox
    Hi
    (A3 1.4 TFSI sportback 2009, 63k, automatic)
    As we have just got the car, I was checking the service records and thought that the S-Tronic gearbox oil hadnt been changed at 38k. So phoned Audi and they checked (over the phone) and said its a sealed gearbox and the oil never needs changing.
    Sounds handy to me!
    I didnt even realise ours is 7 speed and not 6 speed!
    Why arnt they all made like this? any downsides?
    PS. flappy paddles were a bonus, and they work really well.
    mfractal's Avatar
    Jun 2007
    47
    7 speed dsg does need oil changes!
    A3 8P 2.0 TSI MY2010
    APR DP + CAI
    Stage II Custom Tune
    Jan 2014
    23
    Is that for the (as quoted in the service manual)
    1. S-Tronic oil and filter
    or
    2. Multitronic oil
    Because according to the manual, neither of those have been done.
    Is the multitronic gearbox different to my S-Tronic gearbox?
    mfractal's Avatar
    Jun 2007
    47
    Yes, two very different boxes. Yours is s-tronic (dsg).
    APR DP + CAI
    Jan 2014
    23
    ok thanks, but i can only find info that backs up the Audi service dept in saying my 7 speed S-tronic A3 doesnt need oil and filter change.
    Open to anwers.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Thread on this a few months back.
    I have found no auto or DSG box is sealed for life.
    Jan 2014
    23
    So i should phone Audi main dealer back and tell them they are wrong? (did a search, didnt find the thread)
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Consensus on other forums is the box is pressurised to 3 bar and needs NO oil change.
    But any box with oil, IMHO can have it changed. It's a case of, does it really need to.
    check this out..
    To change the fluid in the 7sp DSG you need only 1.7L Gear oil, the Penrite Manual Gear Oil70 is suitable, so it shouldn't be expensive. VW has a track record of whatever component they say it's filled for life (lifetime fill), the life of it is not very long. Most likely 5years/120,000km.
    I'm from old school and change the oil in everything that has the drain plug on regular basis. The transmissions (incl. diffs) are run in between 10,000km - 20,000kmfrom new and require oil change regardless. But, if you keep your car for only for 3-5 years than do what is in the servicing schedule. Here is the link to service schedule in my post; http://www.vwwatercooled.org.au/foru...tml#post684429 to clear up some confusions.
    Jan 2014
    23
    Im no car expert, so i dont feel confident enough to go and tell Audi how to service my car lol.
    I changed a headlight bulb once, in a Mitsubushi. Ended up having to call the AA out as the car wouldnt tick over once i reconnected the battery, turned out you needed to keep your foot on the accelorator for 10 mins to reset the computer settings. After that i said never again.
    Oct 2013
    Brighton & Hove
    70
    Follow Paulc33 On Twitter Visit Paulc33's Instagram Channel
    I used to work in a main dealer and the 7 speeds have life time oil in them and thus don't need changing.
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    The s-tronic or DSG gearbox is basically a manual gearbox with some actuators that change gears for you.
    It needs oil changes in the same way as a manual one: in theory never, in reality it could use changing it from time to time due to debris build ups mostly.
    Now, there are 3 types of s-tronic boxes:
    1. 6 speed with wet clutch. Because in this one has the clutch sitting in oil, more debris will build up and this is why it is recommended to change it every 40k miles or so. Also the oil helps cooling the clutch.
    2. 7 speed with dry clutch. This one doesn't have the clutch immersed in oil so, no need to change it. The oil inside is only to lubricate the gears an you would want to change it the same way you would change it to a manual gearbox. Most people never id it...
    3. 7 speed wet clutch. this is very similar to the 6 speed wet clutch. It is newer though and it is capable to handle more torque than the other two. It can be found on cars like the A5, S5, Tiguan etc. and can be combined with Quattro and transversal engines.
    So, Mr. mreco99, don't worry about oil changes. You don't need to do it.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    Jan 2014
    23
    thanks for the info. Just trying to do things right (within average user limits)
    May 2009
    south yorkshire
    628
    did this on a bmw 530d sealed for life but recommended a change at 100,000 miles . cost me £126 in oil alone, changed it , made no difference at all ,waste of money completely .
  1. Does the A3 have gearbox issue's or any other ?
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th December 2008, 15:11
  2. have you a spare diesel gearbox?...
    By dummi in forum Diesel forum
    Last Post: 19th September 2007, 08:20
  3. How do you know which gearbox you have ??
    By Fuzzman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2005, 17:49
  4. What Gearbox do you have ?
    By spiider in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th December 2004, 16:22
  5. Cam adjuster seals (may have a different name...)
    By cbass in forum General Technical / How To
    Last Post: 20th September 2004, 20:37
