Badger5AH Fabrications
    Sep 2013
    17
    clutch judder all of a sudden in first and reverse and dropping into first or second!
    I cleared dtc's and sprayed silicon spray on actuator and on vane lever last week.lack of power caused me to investigate.
    As soon as job done,went for a test drive and pulling off in first,the car just shudders like a washing machine.does this in reverse as well and wobbles when dropping down to second in general.
    I couldn't see what I was doing behind turbo so silicon spray could've got anywhere.too much of stop starting causes burning smell of some sort.
    power steering stiff when car left for a day then sorts out after a couple of turns.
    some say torque converter
    some say aux belt/alternator clutch
    some say slave cylinder in 6 speed leaking on plate-clutch had always engaged on its own/dragging.
    why only when I cleared codes(which they were old ones)did this happen.
    asv or egr maybe.its horrendous to say the least.
    money-money-money-audis aint funny-theyre a mugs car-lol jokes
    Sep 2013
    17
    oh and I got hit from the side two days previous?
    c_w
    1,061
    Sounds like it's eletrical rather than mechanical. It might just feel like clutch judder but it sounds like an issue with engine loading off idle as you set off. Similar thing happened to my car when the boost pipe popped off; idle was normal and steady, but try and set off and it was like kangaroo city. So it sounds like a sensor fault or something with the stuff you have been spraying about.
  1. Car judders and difficult to put in first gear (not all the time)
    By danonline in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2011, 21:30
  2. Heavy steering,all of a sudden
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th August 2006, 18:42
  3. Clutch Judder
    By jerryhigby in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th January 2005, 11:14
  4. Clutch judder, only done 25k
    By jbreedon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd August 2004, 20:09
  5. Clutch judder, only done 25k
    By jbreedon in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th July 2004, 03:03
