Chris NottSky Insurance
Results 1 to 15 of 15
Thread: Would they fit?
    Mindak's Avatar
    Nov 2013
    Wiltshire
    239
    Would they fit?
    Hi all, been tempted by a set of rota grids cheap!
    they are 18" 9.5j, would they fit mine?
    cheers
    A3 2.0 TDI S-Line
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,815
    You will need to find out the PCD and offset of the wheels and probably the bore diameter
    You need 5x112 with an offset of et55-40/45 at most. From memory, I think the bore is 57.1??
    Mindak's Avatar
    Nov 2013
    Wiltshire
    239
    Quote Originally Posted by Boydie View Post
    Would any of that be stamped on the wheels anywhere?
    A3 2.0 TDI S-Line
    Mindak's Avatar
    Nov 2013
    Wiltshire
    239
    Damn think they might be 5x100 too, will they not fit?
    A3 2.0 TDI S-Line
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,273
    Has to be 5x112.... 5x100 only fits A3/S3 8L's and A1's... All the info should be stamped on the back of the rims... Also the centre bore as Boydie says in 57.1mm anything higher than this... Then you will need spigot rings to fit them safely
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
    Mindak's Avatar
    Nov 2013
    Wiltshire
    239
    So only way I could fit is with pcd adapters... Correct?
    This advisable or shall I bail out?
    A3 2.0 TDI S-Line
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,273
    Thats right man pcd adapters also do the trick... All depends on the offset of the wheels aswell on how much poke will increase...
    depends on how badly you want the rims... Personally I wouldnt use them
    Mindak's Avatar
    Nov 2013
    Wiltshire
    239
    Are they advisable or a no go!
    Don't wanna waste time and money for nice looking wobbly wheels that stick out miles, they would be a spacer too wouldn't they.
    They are already 9.5J
    A3 2.0 TDI S-Line
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    No go.
    Mindak's Avatar
    Nov 2013
    Wiltshire
    239
    2 no goes is good enough for me!
    Shame cos I can get them pretty cheap, may get them and make some money! Lol
    A3 2.0 TDI S-Line
    May 2009
    south yorkshire
    628
    wobble bolts if your'e hard core enough to use them .
    Mindak's Avatar
    Nov 2013
    Wiltshire
    239
    Don't think I'm cool enough! Lol
    A3 2.0 TDI S-Line
    May 2009
    south yorkshire
    628
    lol they actually exist i just wouldnt trust them myself .
    wobble bolts | eBay
    Mindak's Avatar
    Nov 2013
    Wiltshire
    239
    Don't think I fancy them! Lol
    A3 2.0 TDI S-Line
    Dec 2013
    90
    Rotas fitted perfectly, (5x100, 9.5 et38) 15mm spacer at front and 20mm at back. For those who want to know, the back definitely needed a spacer, hit top of the coil mount without! could probably get away with a 5mm at the back if you weren't running 9.5 with a 15mm at the front. Had to go 20mm rear for look and handling characteristics. The clearance between the inner rim protector and the strut in the front however is roughly 2-3mm so JUST fits. Tires are stretched 225 and managed to keep the tread in the arch (rears fine, front just), can definitely lower the car in the rear with no problems, may need to roll arches or camber to the get the fronts nicely inside. One thing to note, these are LOUD rims, the thick flat wall of each spoke gives a very audible propeller like tone, and the spacers create a frequency at around 80kmh that begins to ring and never lets off as speed increases. So, if you're willing to loose a bit of that soundless s3 interior for that wiiiide super phat look, then its well worth it!
  1. Would They Fit??????? Wiper Arms From B6 Cab To B6 Avant?? Long Shot
    By samsam in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th January 2013, 19:43
  2. s5 chrome mirrors, would they fit on a3?
    By snoopi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2012, 05:22
  3. S3 SPRINGS ON A TDI SLINE - Would they fit?
    By andi1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2011, 20:43
  4. Would/Could they fit?
    By RyanS3TT in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2009, 19:05
  5. Brembo's off a Leon Cupra R, Will they fit an S3?
    By Parf7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2003, 11:06
