Sky InsuranceChris Nott
    Dec 2013
    16
    Snap on Modis and coding help!
    Hello!
    im trying to code my a3 8p 2011/2012 to have follow me home lights.
    I can't seem to find any codes or of what I can find I can't find how to use it with the Modis!
    any help/codes/instructions would be more than appreciated!
    Thanks, Jack
    27,089
    Modis isn't a system anyone hardy uses on here tbh mate, however vcds has been discussed allot for the coming home lights, it should follow the same process of module to access, area, coding etc, so you'll have to search the forum for vcds data & see if it corresponds to what Modis shows aswell.
  1. Engine management light on with fans running and 2 fault codes. HELP?!
    By Crunch in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th September 2011, 12:22
  2. vagcom/vcds cruise and front fog light coding help on my a4
    By millwrx in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd January 2011, 17:00
  3. vagcom/vcds cruise and front fog light coding help on my a4
    By millwrx in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th December 2010, 09:32
  4. New here and need help with codes.
    By 98Quattro in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th October 2008, 23:43
