    BenDaniels's Avatar
    Nov 2013
    11
    Window Motor/Door Control Part No. - cannot find any used 8P0 959 801 J
    Hi All,
    I'm trying to find a replacement Control Module/Window Motor for my 2009 A3 Sportback front driver door but cannot find any that matches the part number of my current window motor (8P0 959 801 J - see attached).
    Does anyone know where to find this part or what the letter at the end means as I can find lots of parts with different end letters?
    e.g.
    8P0 959 801 (Genuine AUDI A3 8P S Line Bosch Drivers Side Front Window Motor - 8P0 959 801 | eBay
    or 8P0 959 801 A (Audi A3 Mk2 8P RHF Right Off Side Front Window Motor ECU Module 8P0 959 801 A | eBay)
    or 8P0 959 801 E (Audi A3 Mk2 8P RHF Right Off Side Front Window Motor ECU Module 8P0 959 801 E | eBay)
    or 8P0 959 801 K (MK2 2004-2009 AUDI A3 DRIVER SIDE FRONT WINDOW MOTOR 8P0959801K 8P0 959 801 K | eBay)
    The reason for replacing this part is the drivers door will not unlock with the remote button after being locked for over an hour, all wiring is fine so next step is replace this. See my other thread - Driver door not unlocking with key fob
    Thanks in advance for any help.
    Ben
    Apr 2009
    7
    How did you get on ?
    Quote Originally Posted by BenDaniels View Post
    Hi All,
    e.g.
    Ben
    Hi Ben,
    i have exactly the same problem as you on my 2007 A3 3 door,.. only miine ends in 801K,.. like you i'm not sure what others are compatible,.. did you get it sussed ?
    cheers, Dougie
    Cheers,
    DougieA3
    BenDaniels's Avatar
    Nov 2013
    11
    Hi Dougie, yeah got it fixed but by replacing the lock itself, see my post here: http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/203180-driver-door-not-unlocking-key-fob.html#post2066295. Hope you get it sorted
  1. Some A3 bits - window switches, climate control, door modules...
    By Ash187 in forum For Sale/Wanted - Audi Parts
    Last Post: 27th August 2012, 10:22
  2. Electric window motor part number ?
    By jiffi77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2007, 12:35
  3. Electric Window Motor ???
    Last Post: 3rd January 2007, 09:00
  4. Cruise control part number?
    By awmw in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st December 2006, 19:09
  5. Electric window motor
    Last Post: 10th October 2006, 10:21
