Badger5Volks Autos
Results 1 to 21 of 21
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    EGR blanking plate
    i have just put on a EGR blanking plate on my 2007 a3 tdi 2.0 and sealed the the vacume pipe, i have done 50+ miles today and parked up when i started it up the emission light came on (i think),would it be to do with blanking the egr off or is it something else.
    i have read up on others doing this with no truble,
    i have got 73000 miles on the clock so it shouldn't need any thing major done i hope,i do a lot of motorway driving and drive it like an audi should be driven lol
    Jan 2012
    SW London
    794
    Thats an engine light not emissions light and ive done the exact same thing and have the exact same light. Granted the light will show up for many different things but i have vcds and every scan just shows insufficient flow or something along those lines. Its normal. Weirdly enough sometimes it goes if im driving around town, once ive done some hard driving or long distance it comes back up
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    May 2009
    south yorkshire
    628
    an egr delete is needed in the cars ecu software .
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    so if i take the blanking plate off it sould go out as it has made no dif to the car.
    i cleaned the EGR yesterday and it wasnt to bad, next thing is the inlet manifold to come off and be cleaned when it is dry down here in devon as it all ways rain
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    639
    EGR blanking plate
    Yeah as above the warning lamp will be on because off an egr flow or air flow code.
    Needs the ecu reprogrammed to remove egr.
    If you remove it the lamp will probably go out after a few starts when I realises its ok again.
    IBIS WHITE S3
    Revo stage 2+ and loving it
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    i thought i would try it as it was only £2 from ebay, so a leson lernt
    Dec 2011
    Somerset
    474
    Map out or try the Polo version.
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    polo version ????? or am i being thick lol
    Dec 2011
    Somerset
    474
    The mint with a hole, lol.
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    never seen that one
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    639
    IBIS WHITE S3
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    i will mail them 2 see if it fits mine and thanks
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    742
    You need Part Number:028131547B from the dealer.
    Its the egr gasket that fits with a hole big enough to flow enough gasses to keep the egr light off.
    It costs about £2.50.
    Or you could drill a 7mm hole in your current gasket.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    639
    That's the part number of the one in my eBay link.
    Depends if you've got a dealer local to you or not.
    IBIS WHITE S3
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    i have a dealer not to far away but i will drill a hole in the one i have got and see if that work and thanks again
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    EGR blank without the ECU remap is not a great idea. You need to tell the ECU it isn't opening the EGR, and it will then change the fuel delivery to suit
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Jan 2012
    SW London
    794
    Quote Originally Posted by Rick @ Unicorn Motor Dev. View Post
    Rick
    Could you elaborate on this? How much do you charge to map out the egr?
    VCDS User
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    that is why i am down on power and do you no now that i have taken it off if the lignt will go off on its own or will i have to take it to a garage to clear the ecu
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    639
    After the car has done 3 drive cycles without the fault I'd of thought the warning light will go off itself
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    ideal i will take it for a good drive tomorow and fingers crossed it goes back to normal
    Oct 2012
    492
    I have my egr blanked and I got the egr mapped out with my remap have had no problems sinse loads more power and no lights and no crap getting recirculated round my engine
  1. Performance probs after fitting EGR blanking plates
    By tuffguy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4 Weeks Ago, 22:52
  2. Allard 'Powerpipe' EGR delete kit Vs EGR blanking plates?
    By BudgieV8 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2011, 19:52
  3. EGR Blanking Plates
    By Sammo in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th December 2011, 03:25
  4. EGR blanking plate size 2.5tdi
    By nanafagis in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2011, 11:25
  5. EGR blanking plates
    By ScottD3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st July 2011, 09:01
